    UIFlow for M5Paper
    UIFlow
    12
    16
    28.3k
    • G
      gettys
      Re: UIFlow 1.6.6
      When will UIFlow be available for M5Paper? 1.6.7?
      • ZontexZ
        Zontex
        @gettys said in UIFlow for M5Paper:
        We are working on an update which will be released in the next version.
        V 1 Reply Last reply Reply Quote 0
        • V
          vsthose @Zontex
          @zontex
          Im looking at UIFlow 1.70 (which was the next version) and I still do not see any sign of M5paper? Am I missing something?
          SlartibartfastS 1 Reply Last reply Reply Quote 1
          • SlartibartfastS
            Slartibartfast @vsthose
            @vsthose Use "Beta" for the version when you launch M5Flow and it'll be there. The version you get is 1.6.6 (at least when I do it with the windows desktop version).
            • sodokuS
              sodoku
              @Slartibartfast are you sure? In Beta 1.7.0 I only see Core Ink, but not Paper.
              • D
                Dario
                I can confirm what @sodoku reported. In UIFlow online the Beta version 1.7.0 the M5Paper is not present in the devices list
                • V
                  vsthose @Slartibartfast
                  @slartibartfast When I look at 1.70 BETA, and goto the "Get API" section, the M5Paper is NOT listed.
                  • V
                    vsthose
                    Its been a month now. What is the status of getting the M5Paper into UIFlow?
                    • B
                      bwubs
                      For me the same, no M5Paper is listed when I choose the Beta version in UIFlow
                      • ShotokuTechS
                        ShotokuTech
                        New! M5Paper Now In UIFlow. Check it out!
                        • D
                          dubfitx @ShotokuTech
                          @shotokutech great content thanks, has anyone got an example of how to access the onboard temperature and humidity data? the sht30 is not listed as hardware in uiflow, im having trouble getting anything of sense using i2c.
                            @dubfitx UIFlow is early alpha so expect things not to work.
                            I'm working on an adafruit cap1188 and deciphering reading is a nightmare!
                            • D
                              dubfitx @ajb2k3
                              thanks for the heads up. have things going using arduino ide, looking forward to using uiflow on this.
                              • F
                                follower46
                                So far I've been having a blast with UIFlow on the Paper.
                                I have encountered an error, though, when using "Http Request"
                                When the code is Run through the IDE it works fine but when the code is "downloaded" to the device and an HTTP request is executed it errors with exception OSError 118 which I guess means the wifi is having issues in the application mode but not Run mode.
                                I was able to code around this by adding an additional "wifiCfg.doConnect('AP', 'AP_Password')" before the code is executed.
                                Other than that it's fantastic using UIFlow for development!
                                • K
                                  ksprayberry
                                  I’ve got a program that uses several HTTP Get statements for stock quotes and weather. I don’t know that I encountered that error. I do have the WIFi connect like in my setup though. I had issues parsing the json file I got back on the weather, but that is more user error that anything I think. I ended up editing much of my code after I roughed it out in the blocky side. I’ve really enjoyed the Paper in UIFlow though too.
                                    oserror 118 is an issue with Micropython. from what i can tell, its an issue baffling the main MP devs.
