    Is there a deep sleep mode for Fire?
    M5Stack Fire
    7.6k
    • H
      houkensjtu
      Hello all,
      I'm designing a Fire application which is supposed to be work on battery, and it will be beneficial if I can deep sleep Fire when it's not being used. Is there a way to "Sleep" the unit? Or what's the most common way to reduce power consumption?
      Thank you!
        Hello @houkensjtu
        yes, there is. Two functions are available for that POWER::lightSleep() and POWER::deepSleep()
        Also have a look at the sleep example, it uses light sleep and deep sleep functionality.
        Cheers
        • H
          houkensjtu
          Hi Felix,
          Thank you for you quick answer. Looks like you're referring to the Arduino library of M5Stack.
          I wonder if there is an equivalent function in UI-FLOW? I'm currently using UI-Flow to program my Fire.
          I can also try to burn the Arduino firmware, but I'm worried if I can control the UI as easily as in UI-Flow.
          Thx,
            Hello @houkensjtu
            ok, I see. In UI-FLOW you could use an Execute code block and add something like this for deep sleep:
            import machine
            #sleep for 10 seconds
            machine.deepsleep(10000)
            or light sleep:
            import machine
            machine.lightsleep(10000)
            BTW: I found a nice tutorial about MicroPython and sleep modes here.
            Cheers
