    Wifi-connect layer still shown
    3 Posts 3 Posters 3.9k Views
      potok
      Hello Guys,
      pardon me if this is wrong section.
      I just got M5stack core2, and I have a problem that when in UIFlow I create a program to connect to wifi and afterwards show any data. Wi-fi connect "screen" is shown on background even if I do clear lcd and set-background
      also I tried to create full screen label on layer 3 and it was OK.
      Please do you have any idea what I am doing wrong?
      • m5stackM Online
        could you share your program? the m5f file. or take a screenshot.
        • W Offline
          WouterG
          Hello there, i have the same problem. When i use the "RUN" button on https://flow.m5stack.com/ then i have no problem, everything is working as expected. But when i download then the Wi-Fi Connect page is shown behind the text labels i use.
          This is the only code i use at the moment:
          from m5stack import *
          from m5stack_ui import *
          from uiflow import *
          from m5mqtt import M5mqtt
          screen = M5Screen()
          screen.clean_screen()
          m5mqtt = M5mqtt('SchermWoonkamer', '192.168.1.100', 1883, '', '', 300)
          label0 = M5Label('Text', x=7, y=7, color=0x000, font=FONT_MONT_14, parent=None)
          def fun_domoticz_out_(topic_data):
          global params
          label0.set_text(str(topic_data))
          pass
          m5mqtt.subscribe(str('domoticz/out'), fun_domoticz_out_)
          m5mqtt.start()
          label0.set_text('Opgestart')
