2 question while await my core 2, power and pinouts
 after returning a faulty M5Stack grey I ordered an M5Stack core 2, it's due next week!I'm designing my own board for it and have the following questions: - is the stackable header the same pinout on all of the core range?
- I don't want or need the internal battery instead I need to power from 12v so if I add a power regulator do I connect it to the 5V pin on the header? or I could build it to provide 3.3V and connect it to that pin! so I guess my question is how best to externally power an M5Stack via the header?
- lastly, if powered via the 5V header pin will it switch on and off with the power?
 Hello @wadoadi -
No, the M5 Bus is slightly different for M5Core2. I've made a comparison sheet.
Yes, that is how I power one of my M5Core2 - via 5V pin.
 But you'll need to modify the M5Core2 library code as currently it turns off the 5V input shortly after boot. The function call in question is:SetBusPowerMode(0);- which needs to be modified toSetBusPowerMode(1);. You also need a fixed version ofSetBusPowerMode()- see here.
 I haven't tried, but I don't think powering from 3.3V is possible - according to the M5Core schematic there are multiple 3.3V power lines inside the M5Core2 and the one connected to the M5 Bus,MCU_VDD, only powers ESP32, flash, RAM, etc., but for instance not the LCD which is powered throughPERI_VDD.
Yes, but only if the battery has been removed.
 Cheers
 @felmue Wow thank you for all the information
