    Using G33 analogRead while connected to Wi-Fi
    5 Posts 2 Posters 7.7k Views
      dollychun
      First of all, this is my first post so please let me know if there is problem
      So I thought I'd do an analog read with the G33 pin, but it worked fine at first, but when I added the code to do the wifi communication, the G33 analog read always returned 4098.
      I searched and found that using ADC2 with analogread during wifi communication always returns 4098, but the G33 pin is ADC1.
      I don't know what's wrong, please help!
        Hello @dollychun
        using GPIO33 as analog input and WiFi works for me. M5Atom is connected to WiFi and I get values from 0 to 4095 from GPIO33. Care to share your code?
          dollychun
          @felmue Heres my code
          #include "M5Atom.h"
          #include "WiFi.h"
          int analogIn = 33;
          const char* ssid       = "PatoWiFi";
          const char* password   = "PatoWifi_Password";
          WiFiClient client;
            // put your setup code here, to run once:
            M5.begin(true, false, true);
            Serial.begin(115200);
            pinMode(analogIn, INPUT);
            WiFi.begin(ssid, password);
            Serial.print("Connecting to WiFi");
            while(WiFi.status()!=WL_CONNECTED) {
              delay(500);
              Serial.print(".");
            Serial.print("OK");
            Serial.print("\r\nWiFi connected\r\nIP address: ");
            Serial.println(WiFi.localIP());
            client.connect("www.someurl.com", 80);
            Serial.println("sending data to server");
            client.println("POST / HTTP/1.1");
            client.println("Host: www.someurl.com");
            client.println("User-Agent: ESP32/M5Atom");
            client.println("Accept */*");
            client.println();
            unsigned long timeout = millis();
            while (client.available() == 0) {
              if (millis() - timeout > 5000) {
                Serial.println(">>> Client Timeout !");
                client.stop();
            Serial.println("receiving from remote server");
            // not testing 'client.connected()' since we do not need to send data here
            while (client.available()) {
              char ch = static_cast<char>(client.read());
              Serial.print(ch);
            // Close the connection
            Serial.println();
            Serial.println("closing connection");
            client.stop();
            WiFi.disconnect();
            // put your main code here, to run repeatedly:
            int val = analogRead(analogIn); // Always return 4095
            Serial.printf("AnalogRead = %d\n", val);
            delay(100);
            Hello @dollychun
            Hmm, I am running your code (with my WiFi credentials) on an M5Atom Matrix and reading GPIO33 is fine.
            I get 0 when GPIO33 is connected to GND and 4095 when connected to +3.3V and values in between when floating as expected.
            AnalogRead = 0
            AnalogRead = 544
            AnalogRead = 16
            AnalogRead = 4095
            Have you confirmed that reading GPIO33 works again if you comment out the WiFi code? Maybe adding that isn't the cause that made reading GPIO33 stop working?
              dollychun @felmue
              @felmue said in Using G33 analogRead while connected to Wi-Fi:
              Yes. I have confirmed that it works when I remove the Wifi code...
              I will try this with another atom...
