Power on via RTC timer example
Hi guys
Recently, while looking at the M5Core2 schematic, I realised that the fine M5Stack engineers connected the RTC interrupt output to the power key input of the AXP192. This means the RTC IC can power on a fully shutdown M5Core2 by either using a timer or an alarm.
I've put together an example showing how to setup an RTC timer to power on the system.
Cheers
Felix -
Hi @felmue, Tested your code on M5Core2 works perfectly fine - it can also work with deep sleep function not just the normal sleep mode, I merged it with our master repository, thank you for your contribution!
Hello @Zontex
cool, thanks.
Regarding deep sleep: I don't think it works as expected. When I call
M5.Axp.DeepSleep(1000 * 1000 * 2);
I'd expect the system to restart from deep sleep after about 2 seconds, but instead the system shuts down completely and never wakes up again from deep sleep.The reason I think is that
SetSleep()
turns off power to the ESP32 IC and therefore line(time_in_us == 0) ? esp_deep_sleep_start() : esp_deep_sleep(time_in_us);
is never executed and the system never goes into deep sleep but is shutdown completely.Note: If I comment out
SetSleep()
then deep sleep works as expected.I've submitted a issue for the deep sleep issue: https://github.com/m5stack/M5Core2/issues/17
Felix -
@felmue I'll have a look into this issue, I only tested the commented out version and it worked fine but if it's not commented out it does as you say, will look into it.
Hi @Zontex
thank you for looking into it, I appreciate it. Please let me know if there is anything I can help with or test.
