    V-function Face Detect not working on Unit-V
    9 Posts 3 Posters 15.0k Views 1 Watching
    • world101W Offline
      world101
      Just got a Unit-V and was trying to use the face detection V-function. I burned the FaceDetect v1.1 firmware to the Unit-V using the M5Burner. I used the example in the docs (but on an M5StickC-Plus instead of a core) and I can't get it to detect anything.
      Looking at the serial logs of the Unit-V, there is this error:
      [MAIXPY]Pll0:freq:832000000
      [MAIXPY]Pll1:freq:398666666
      [MAIXPY]Pll2:freq:45066666
      [MAIXPY]cpu:freq:416000000
      [MAIXPY]kpu:freq:398666666
      [MAIXPY]Flash:0xef:0x17
      open second core...
      gc heap=0x801b4c30-0x80234c30(524288)
        File "_boot.py", line 11, in <module>
        File "pmu.py", line 53, in __init__
      NotFoundError:
      MicroPython v0.5.0-98-g7ec09ea22-dirty on 2020-08-05; Sipeed_M1 with kendryte-k210
      I think the firmware is not correct for the Unit-V. Any ideas?
        dsrc12
        Hello world101, I have a similar problem. None of the UIFlow Unit V examples work. I am using a M5StickC and the latest firmware on both M5StickC (1.6.4) and Unit V. I would appreciate better help from M5Stack - there are no examples, no help and little documentation - it is all guess work. Others have suggested differences between the two V modules and a flip in image orientation may be required.
        • m5stackM Offline
          it is a bug. we will fix it as soon as possible.
          actually, we have provided the tutorial document
          https://docs.m5stack.com/#/en/quick_start/unitv/v_function
          • m5stackM Offline
            we just release a new firmware. you could remove the firmware then redownload it(same firmware version number) in the M5Burner firmware list. will be ok
            world101W D 2 Replies Last reply Reply Quote 0
            • world101W Offline
              world101 @m5stack
              @m5stack said in V-function Face Detect not working on Unit-V:
              Thanks. With the updated firmware, now I have the face detection v-function working now with the example in the docs.
                dsrc12 @m5stack
                @m5stack Thanks for the link. I would recommend that you put a link to this tutorial from the product documentation
                  dsrc12 @dsrc12
                  @dsrc12 I still can not get any of the code software modules such as Bar code or April Tag to work with either M5StickC Plus or Fire. Here are some of my screen shots.
                  • m5stackM Offline
                    m5stack @dsrc12
                    @dsrc12 you could change the tag class. the v-function only supported the Tag36H11
                      dsrc12 @m5stack
                      @m5stack I have tried Tag36H11 images for numbers and this makes no difference. UnitV with M5Stack Fire and UIFlow did not decode the images. I did not make any alternation to my UIFlow code. Did you test this software?
