    no module named m5stack_ui
    M5stack Grey
    5
    6
    9.2k
    • Z
      zenman
      It has taken me many hours to get UIFlow to 'partially' work.
      I can finally connect through the windows based UI flow. Through USB I can upload programs and those work. hooray!
      My current problem is when I switch to the internet version. I am able to connect to wifi and even connect to my device using the internet version. But when I try to press the play button on the internet UI flow I get this error:
      "no module named m5stack_ui"
      When I press the detail button it says:
      file "<string>", line 2, in <module>
      ImportError: no module named m5stack_ui
      Do I need to install something to fix this?
      • W
        wmantilla @zenman
        @zenman I have the same error in my first test, Not a good start M5stack
        • C
          ciconde
          Same problem here
          No solution yet?
          • C
            ciconde
            @m5stack Can you please help here?
            I've flashed 1.9.4-en and 1.9.5-en versions without luck...
            It's only happening if I "run" the program. In both versions if I do the "download" then screen just go blank.
              What Controller are you running?
              • J
                JDZAWODNIAK
                This worked for me... https://community.m5stack.com/topic/3861/solved-importerror-no-module-named-m5stack_ui
