    M5STACK C PLUS
    General
    8.0k
      soky157
      The screen has a left over image that wont go way. Newer sketches/examples now share the screen with the left over image that looks something like a bar code.
      I would appreciate any help in clearing the screen.
      soky157
      • vkichlineV
        vkichline
        Are you using Arduino or UIFlow? May be the same in both cases:
        The first time I programmed my M5StickC PLUS, I included the old M5Stick library, and got exactly the visual effect you mention.
        Use the M5StickCPlus library for Arduino.
        I haven't used UIFlow for a while, but perhaps there you need to be sure to select the M5StickC PLUS board and not M5StickC.
        The PLUS has a larger display, so the library compiled for the older, smaller display only addresses part of the LCD.
          soky157
          Thank you for your help. M5STICKC PLUS isnt listed in arduino boards mgr. I contacted M5STACK and responded that there is NOT supposed an M5STACKC PLUS listed in Arduino Boards mgr. So i tried Easyloader and burned the firmware and all is perfect now.
          • vkichlineV
            vkichline
            Sorry, I wasn't clear, but it sounds like we're on to it.
            Keep the M5StickC board selected, but change:
            #include <M5StickC.h>
            to
            #include <M5StickCPlus.h>
            • m5stackM
              M5StickC and M5StickC Plus both use the M5StickC board in Arduino.
              but they use different libraries.
              you could follow this tutorial to setup.
              https://docs.m5stack.com/#/en/arduino/arduino_development
