    problem with m5stack (with mpu9250)
    PRODUCTS
    5
    13.6k
      Suslikman
      i , there are problems with m5stack. When connected to a PC(win 10), the device is not defined
      • A
        anichang @Suslikman
        @suslikman
        You must install the CP210X usb drivers for windows to recognize the device:
        1. install drivers.
        2. reboot.
        3. connect the usb cable.
        Drivers are available on the website, download button on the upper bar, last link at the bottom.
          Suslikman
          @anichang 在 problem with m5stack (with mpu9250) 中说:
          reboot.
          this does not help, the drivers are installed, another usb cable is purchased, the PC can not see at all its
          • m5stackM
            maybe u try another use cable or plug deeper?
            • JJJ
              JJ @Suslikman
              @suslikman
              I am using M5Stack with Windows 10 - 64 bit on 3 different systems and M5Stack works fine on all. No issues.
              On one machine originally the drivers did not install correctly - though it wasn't obvious at the time.
              To check driver installation worked correctly:
              • Dis-connect M5Stack from PC if connected. Turn up PC volume. Open device manager. Connect M5Stack using USB cable.... once M5Stack is connected, you should hear a Windows sound - "bing""- and now in the device manager a new item should magically appear called "Ports” Click on it – it should show the Silicon Labs driver listed.
              If not , you need to re-install the driver - make sure Python is on your Windows path. You can verify the path is working by opening command prompt and typing - python.
              Are these files (below) available after you have Python installed and after you run get.exe ? They should be.
