    Core2: Vibration motor intensity setting support..
    Bug Report
    9.6k
    • SkinkS
      Skink
      @m5stack
      With "Set vibration intensity" alone the vibration motor does not work at all, no matter if 1-100%.
      If I switch it on with "Set vibration enable (true)" the motor will vibrate but with the same intensity, I try to change the intensity with "Set vibration intensity" but nothing happens.
      I can only switch it off with "Set vibration enable (false)"!
        Hello @Skink
        that is not very surprising. To set the vibration intensity an underlying function SetLDOVoltage() is used which currently is broken in M5Core2 library as pointed out by @veryalien :
        https://github.com/m5stack/M5Core2/issues/4.
        I've proposed a fix in a pull-request which got closed as it should be fixed in the near future anyways as @Hades2001 pointed out:
        https://github.com/m5stack/M5Core2/pull/5
        Cheers
          Hi @Skink
          here is a Python solution. Button A decreases, Btn C increases intensity. Btn B turns vibration motor on and off:
          from m5stack import *
          from m5stack_ui import *
          from uiflow import *
          import i2c_bus
          screen = M5Screen()
          screen.clean_screen()
          label0 = M5Label('Text', x=52, y=67, color=0x000, font=FONT_MONT_24, parent=None)
          from numbers import Number
          motorOnOff = None
          motorValue = None
          temp = None
          def setMotorValue():
            global motorOnOff, motorValue, temp
            label0.set_text(str(motorValue))
            temp = (i2c0.read_u8(0x28)) & 0xF0
            temp = temp | motorValue
            i2c0.write_mem_data(0x28, temp, i2c_bus.UINT8LE)
          def buttonA_wasPressed():
            if motorValue > 0:
              motorValue -= 1
            setMotorValue()
            pass
          btnA.wasPressed(buttonA_wasPressed)
          def buttonC_wasPressed():
            if motorValue < 15:
              motorValue += 1
            setMotorValue()
            pass
          btnC.wasPressed(buttonC_wasPressed)
          def buttonB_wasPressed():
            motorOnOff = not motorOnOff
            power.setVibrationEnable(motorOnOff)
            pass
          btnB.wasPressed(buttonB_wasPressed)
          i2c0 = i2c_bus.easyI2C(i2c_bus.PORTA, 0x34, freq=400000)
          motorOnOff = False
          motorValue = 7
          setMotorValue()
          Cheers
          SkinkS 1 Reply Last reply Reply Quote 1
          • SkinkS
            Skink @felmue
            Hello Felix,
            Thank you, I have tested your program and it works perfectly. Thank you very much for that !
            THX skink
              Hi skink
              you're very welcome.
              The required fix mentioned before has now been included to the M5Core2 library so hopefully in one of the next UIFlow updates it will be picked up.
              Happy Stacking!
