Installing "M5Stack-IDF" will result in errors
I installed M5Stack-IDF and I got errors:
My steps:
Download and install esp-idf from https://github.com/espressif/esp-idf
Check version: %
Input: idf.py --version
Result: ESP-IDF v4.3-dev* -
Install M5Stack
Input: %git clone --recursive https://github.com/m5stack/M5Stack-IDF.git -
Input: %make menuconfig
Switch on "Autostart Arduino setup and loop on boot" -
Compile
Input: %make flash monitor -
Get errors:
a.) /Users/<name>/esp/M5Stack-IDF/components/arduino/cores/esp32/libb64/cencode.c:
In function 'base64_encode_block':
/Users/<name>/esp/M5Stack-IDF/components/arduino/cores/esp32/libb64/cencode.c:49:20:
warning: this statement may fall through [-Wimplicit-fallthrough=]
result = (fragment & 0x003) << 4;
/Users/<name>/esp/M5Stack-IDF/components/arduino/cores/esp32/libb64/cencode.c:52:9:
note: here
case step_B:Workaround: Insert "__attribute__ ((fallthrough));"
b.) /Users/<name>/M5Stack-IDF/components/arduino/cores/esp32/esp32-hal-gpio.c:86:24: error:
'rtc_gpio_desc' undeclared (first use in this function); did you mean 'rtc_io_desc'?
uint32_t rtc_reg = rtc_gpio_desc[pin].reg;
_________________ ^~~~~~~~~~~~~
__________________rtc_io_desc
/Users/<name>/esp/M5Stack-IDF/components/arduino/cores/esp32/esp32-hal-gpio.c:86:24: note:
each undeclared identifier is reported only once for each function it appears in
make[1]: *** [cores/esp32/esp32-hal-gpio.o] Error 1Workaround: No workaround known yet
Can anyone help me?
Hi @sheepDog
I get the same errors. I am afraid that
M5Stack-IDF
is too old (updated 2 years ago) to work with the latestesp-idf
. For one thing Espressif has since moved on to useCMake
& python scrips to build instead of justmake
. (I am not that familiar with either, but I think they don't play well mixed together.)Just curious. What is it that makes you want to use the
idf
instead of an Arduino environment?Thanks
Felix -
Hello @felmue,
thank you for your interesting informations.
The two main reasons why I use IDF are:
I am developing a large project and so I need an IDE that can handle such a project clearly. For example, it becomes quite confusing when you have more than 20 files.
I wanted to be very close to the examples of expressif, because in past I got some unpleasant mistakes in some libraries.
hey @sheepDog, take a look at the following repo: M5Stack-IDF-4.0, maybe it can be of use to setup a IDF 4.0 environment as you'd like
Hi @brus,
thank you for providing your repro. In the meantime I've put together my own version and I'm waiting for the official version of m5stack.
FWIW & IMHO, Arduino is far to limiting. IDF opens up far more options that Arduino just does not address.
Menuconfig is the primary reason for me to use IDF, and like the other poster said, having many source files Arduino is just to crippling to large projects beyond twinkling a led.I too hope M5Stack comes out with an updated official version of m5stack for IDF.
