<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved]Schematics for M5StickC?]]></title><description><![CDATA[<p dir="auto">Is there any plan to publish the schematics of M5StickC?</p>
]]></description><link>https://community.m5stack.com/topic/980/solved-schematics-for-m5stickc</link><generator>RSS for Node</generator><lastBuildDate>Thu, 23 Apr 2026 02:55:51 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/980.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 May 2019 12:45:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Mon, 21 Sep 2020 05:57:21 GMT]]></title><description><![CDATA[<p dir="auto">It is for M5StickC Plus. M5StickC is nearly the same:<br />
<a href="https://docs.m5stack.com/assets/img/product_pics/core/minicore/m5stickc_plus/StickC_sch.webp" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/assets/img/product_pics/core/minicore/m5stickc_plus/StickC_sch.webp</a></p>
]]></description><link>https://community.m5stack.com/post/10151</link><guid isPermaLink="true">https://community.m5stack.com/post/10151</guid><dc:creator><![CDATA[lukas]]></dc:creator><pubDate>Mon, 21 Sep 2020 05:57:21 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Tue, 30 Jun 2020 20:05:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3805">@morris45</a> said in <a href="/post/9195">[Solved]Schematics for M5StickC?</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a> If I power down the M5StickC by pressing the power button for 6 seconds, the current consumption is 0mA, so the AXP192 can turn everything off, like IMU, display etc. How do I tell the AXP192 to only turn on the ESP32 and keep the IMU etc turned off?</p>
<p dir="auto">That way I will only have the current consumption of the AXP192 and ESP32 (10uA).</p>
<p dir="auto">Seems to me like the IMU MPU6886 is powered via VESP_3V3, which is driven by the AXP192's DC/DC-converter 1 DCDC1, which also supplies the ESP32.</p>
<p dir="auto">According to the MPU6886 datasheet, the regular power consumption with all 6 axes on is around 2.8mA, which matches your observations of 2mA. You can use the low power modes down to 45µA (only Accelerometer), or Full-Chip Sleep mode at 10µA (see p. 11).</p>
<p dir="auto">On power up the IMU defaults to Sleep Mode (see p. 32), so maybe it is sufficient to not initialize it. Otherwise you would have to turn it off by writing to register PWR_MGMT. For full power down, no standby must be set (see section 9.9, p. 52.)</p>
<p dir="auto">Unfortunately the M5StickC-library does not offer an interface for any of those power management features.</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a>: It would be a big help to have power management support in the library, and an example that demonstrates different power consumption states (maybe with the coulomb counter to get a real integral power consumption). Also a great example to prove that M5StickC is usable as a wearable and standalone device for more than just a few minutes.</p>
<p dir="auto">The RTC would be able to trigger an interrupt on a preset alarm time, or with a timer. But I'm not sure if this is sufficiently connected to the PMU AXP192 to wake it up from complete system power down. This would be something <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a> could probably answer.</p>
]]></description><link>https://community.m5stack.com/post/9204</link><guid isPermaLink="true">https://community.m5stack.com/post/9204</guid><dc:creator><![CDATA[trapicki]]></dc:creator><pubDate>Tue, 30 Jun 2020 20:05:59 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Tue, 30 Jun 2020 02:05:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3805">@morris45</a> we don't have example code to setup it low power to 10ua. even if you shutdown the IMU  and screen . current still is mA level</p>
]]></description><link>https://community.m5stack.com/post/9198</link><guid isPermaLink="true">https://community.m5stack.com/post/9198</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 30 Jun 2020 02:05:11 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Mon, 29 Jun 2020 21:21:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a> If I power down the M5StickC by pressing the power button for 6 seconds, the current consumption is 0mA, so the AXP192 can turn everything off, like IMU, display etc. How do I tell the AXP192 to only turn on the ESP32 and keep the IMU etc turned off?</p>
]]></description><link>https://community.m5stack.com/post/9195</link><guid isPermaLink="true">https://community.m5stack.com/post/9195</guid><dc:creator><![CDATA[Morris45]]></dc:creator><pubDate>Mon, 29 Jun 2020 21:21:48 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Mon, 29 Jun 2020 09:24:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3805">@morris45</a> i has ask our engineer .   even if the esp32 deepsleep, other electronic component still work. like imu, axp192 etc. even if you seting the IMU to sleep mode the esp32 can't  possible low power to 10uA.</p>
]]></description><link>https://community.m5stack.com/post/9194</link><guid isPermaLink="true">https://community.m5stack.com/post/9194</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 29 Jun 2020 09:24:42 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Mon, 29 Jun 2020 08:18:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a> If you won't release the schematic, can you tell us why the M5StickC still draws 2mA in deepsleep, and not 10uA like the ESP32 should?</p>
]]></description><link>https://community.m5stack.com/post/9192</link><guid isPermaLink="true">https://community.m5stack.com/post/9192</guid><dc:creator><![CDATA[Morris45]]></dc:creator><pubDate>Mon, 29 Jun 2020 08:18:38 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Mon, 29 Jun 2020 02:13:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3805">@morris45</a> for the time being. only provide pin map schematic.  don't provide electronic component parameters.</p>
]]></description><link>https://community.m5stack.com/post/9187</link><guid isPermaLink="true">https://community.m5stack.com/post/9187</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 29 Jun 2020 02:13:02 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Sun, 28 Jun 2020 18:06:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a> That is not a schematic. For example: apparently there isn't a single resistor on the M5StickC.</p>
<p dir="auto">I've got my M5StickC in pieces trying to reduce power consumption for increased battery life, and I can see at least 20 resistors without even counting properly.</p>
<p dir="auto">When will you be releasing the schematic?</p>
]]></description><link>https://community.m5stack.com/post/9182</link><guid isPermaLink="true">https://community.m5stack.com/post/9182</guid><dc:creator><![CDATA[Morris45]]></dc:creator><pubDate>Sun, 28 Jun 2020 18:06:51 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Thu, 04 Jun 2020 01:18:47 GMT]]></title><description><![CDATA[<h3>M5StickC Schematic</h3>
<p dir="auto"><img src="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/schematic/Core/M5StickC/m5stickC.webp" alt="替代文字" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/8896</link><guid isPermaLink="true">https://community.m5stack.com/post/8896</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 04 Jun 2020 01:18:47 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Wed, 03 Jun 2020 15:52:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1970">@avg</a> said in <a href="/post/5457">[Solved]Schematics for M5StickC?</a>:</p>
<p dir="auto">I was looking for the schematic because I wanted to understand whether the IMU interrupt pins were routed to a GPIO.</p>
<p dir="auto">Me too ! ! !</p>
]]></description><link>https://community.m5stack.com/post/8894</link><guid isPermaLink="true">https://community.m5stack.com/post/8894</guid><dc:creator><![CDATA[sgallou]]></dc:creator><pubDate>Wed, 03 Jun 2020 15:52:31 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Wed, 04 Sep 2019 21:16:48 GMT]]></title><description><![CDATA[<p dir="auto">I was looking for the schematic because I wanted to understand whether the IMU interrupt pins were routed to a GPIO.</p>
]]></description><link>https://community.m5stack.com/post/5457</link><guid isPermaLink="true">https://community.m5stack.com/post/5457</guid><dc:creator><![CDATA[avg]]></dc:creator><pubDate>Wed, 04 Sep 2019 21:16:48 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Mon, 02 Sep 2019 18:16:30 GMT]]></title><description><![CDATA[<p dir="auto">Any chance to get the correct schematic of M5stick C</p>
<p dir="auto">I was thinking that the one on Github was correct but is the old M5stick</p>
<p dir="auto">I think it should be very beneficial to have he complete schematic and not just a block diagram (by the way not precise..ie RTC missing..)</p>
<p dir="auto">At the end of the day M5stick C is a proto board (indeed very nice) done for makers and developers...people who want to exploit potential from your product and  not having access to the schema seems a sort of contradiction</p>
<p dir="auto">I hope you can release the schema and off course I respect anyway your philosophy</p>
<p dir="auto">Davide</p>
]]></description><link>https://community.m5stack.com/post/5431</link><guid isPermaLink="true">https://community.m5stack.com/post/5431</guid><dc:creator><![CDATA[arzaman]]></dc:creator><pubDate>Mon, 02 Sep 2019 18:16:30 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Thu, 08 Aug 2019 09:41:04 GMT]]></title><description><![CDATA[<p dir="auto">Sure it would. <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/480">@heybin</a> what is the status ? They have been promised on Twitter too but still not published.</p>
<p dir="auto">Thank you !</p>
]]></description><link>https://community.m5stack.com/post/5067</link><guid isPermaLink="true">https://community.m5stack.com/post/5067</guid><dc:creator><![CDATA[Oliv&#x27;]]></dc:creator><pubDate>Thu, 08 Aug 2019 09:41:04 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Tue, 06 Aug 2019 11:07:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/481">@m5-docs</a></p>
<p dir="auto">Block diagram level documentation showing the power management chip connections, would help those attempting to improve code to reduce sleep mode power consumption.</p>
]]></description><link>https://community.m5stack.com/post/5044</link><guid isPermaLink="true">https://community.m5stack.com/post/5044</guid><dc:creator><![CDATA[maxstack]]></dc:creator><pubDate>Tue, 06 Aug 2019 11:07:08 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Thu, 11 Jul 2019 17:20:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1152">@liushasha</a> said in <a href="/post/4791">[Solved]Schematics for M5StickC?</a>:</p>
<p dir="auto">Hi,<br />
M5StickC schematic is not permitted to be open source yet, maybe later. We have offered the block diagram on the back sticker of the device, include all components and pin layout. Do you think those info is enough ?</p>
<p dir="auto">Not quite enough info. The question I have (and others too from another thread), is there any clamping or level shifting circuit (5V down to 3.3V) between the Grove port and I/O pins (G0, G26, G36) to the ESP32? If not, an external device (sensor) could pass 5V back into the M5stickC via Grove or I/O pins and damage the ESP32.</p>
]]></description><link>https://community.m5stack.com/post/4793</link><guid isPermaLink="true">https://community.m5stack.com/post/4793</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Thu, 11 Jul 2019 17:20:15 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Thu, 11 Jul 2019 01:15:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
]]></description><link>https://community.m5stack.com/post/4791</link><guid isPermaLink="true">https://community.m5stack.com/post/4791</guid><dc:creator><![CDATA[liushasha]]></dc:creator><pubDate>Thu, 11 Jul 2019 01:15:42 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Tue, 09 Jul 2019 11:03:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/480">@heybin</a> said in <a href="/post/4715">[Solved]Schematics for M5StickC?</a>:</p>
<p dir="auto">sure, it will available in next week</p>
<p dir="auto">Did you release the schematic yet? Not sure how m5stack designed and built the m5stickC hardware without a finished schematic 🤷🏼‍♂️</p>
]]></description><link>https://community.m5stack.com/post/4783</link><guid isPermaLink="true">https://community.m5stack.com/post/4783</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Tue, 09 Jul 2019 11:03:58 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Fri, 28 Jun 2019 01:00:42 GMT]]></title><description><![CDATA[<p dir="auto">sure, it will available in next week</p>
]]></description><link>https://community.m5stack.com/post/4715</link><guid isPermaLink="true">https://community.m5stack.com/post/4715</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Fri, 28 Jun 2019 01:00:42 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Wed, 26 Jun 2019 10:05:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/481">@m5-docs</a> if no schematics - can you answer some questions?</p>
<p dir="auto">As I am see, esp32 power connected to DC1 of AXP192.<br />
LCD back light connected to LDO2 of AXP192.</p>
<p dir="auto">Questions:</p>
<li>What connect to DC2, DC3, LDO1, LDO3?</li>
<li>Can I am reduce power consumption by power off LCD module (not backlight)?</li>
<li>Can I am reduce power consumption by power off MIC, RTC, GYRO?</li>
<p dir="auto">May be schematics will be available soon? Please.</p>
]]></description><link>https://community.m5stack.com/post/4702</link><guid isPermaLink="true">https://community.m5stack.com/post/4702</guid><dc:creator><![CDATA[amurchick]]></dc:creator><pubDate>Wed, 26 Jun 2019 10:05:34 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]Schematics for M5StickC? on Mon, 06 May 2019 04:02:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1232">@hackbeere</a> Sorry, We have never had its schematic</p>
<p dir="auto"><a href="https://docs.m5stack.com/#/en/core/m5stickc" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/core/m5stickc</a></p>
]]></description><link>https://community.m5stack.com/post/4146</link><guid isPermaLink="true">https://community.m5stack.com/post/4146</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 06 May 2019 04:02:56 GMT</pubDate></item></channel></rss>
