<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Make M144 - Audio Module true STEREO]]></title><description><![CDATA[<p dir="auto">I found a design issue (or corner cut) in the HW design phase that dramatically reduce the versatilty of this extremely nice board.<br />
On the Audio signal path from Input LINE/MIC 3.5mm TRS, there is a circuit that feed the microphone signal from the IN/OUT TRRS Jack.<br />
I get the logic behind this decision but the implementation affect the frequency response on the LIN1 path.<br />
The result?<br />
You cannot use the board to process analog stereo signals as RIN1 frequency response is flat at the HW input and LIN1 isn't!</p>
<p dir="auto">My solution would be to add an electronic switch (maybe a TS12A12511) on the MIC_MONO_IN between R9-C14 node and FSUSB42MUX to cut that path entirely.</p>
<p dir="auto">The control signal can be tied with  LIN_MIC_PU_EN from the STM32G030; when the Headphones Electret is energised, the path to LIN1 would be restored.<br />
A better solution would be to make the control separate and use one of the available GPIOs on STM32G030 and a separate I2C command on 0x33 address.</p>
<p dir="auto">It is so simple...</p>
<p dir="auto">This will eliminate the need to physically remove C9 in order to get a flat response for BOTH Line inputs thus having a STEREO Audio Module.<br />
See this also: <a href="https://yo3hjv.substack.com/p/ham5dsp-another-hw-problem-with-m5stack" target="_blank" rel="noopener noreferrer nofollow ugc">My findings about this</a></p>
<p dir="auto">I even asked M5 AI for this issue and it was funny because it didn't knew about this issue:</p>
<p dir="auto"><strong>If you're seeing different frequency response between left and right, the most likely cause is:<br />
One channel's HPF is enabled while the other is not (rolls off low frequencies)<br />
Different PGA gain settings between channels<br />
The two physical mic inputs may have different input impedance/coupling characteristics</strong></p>
<p dir="auto">Cheers,<br />
Adrian</p>
]]></description><link>https://community.m5stack.com/topic/8264/make-m144-audio-module-true-stereo</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 06:58:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8264.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 Jun 2026 03:57:50 GMT</pubDate><ttl>60</ttl></channel></rss>
