<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[⚠️ M5Stack Core2 v1.3 -  Ouroboros-like power loop -]]></title><description><![CDATA[<p dir="auto">Hi all, I’m investigating a power management issue on the M5Stack Core2 (AXP192 + external SY7088 boost) and I’m looking for confirmation or a proper solution.</p>
<p dir="auto">🔧 System Architecture (as implemented)<br />
From schematic analysis and testing:</p>
<p dir="auto">AXP192 IPSOUT powers the system and the boost converter</p>
<pre><code>// VBUS ALWAYS INPUT ENABLED
 writeAxpReg(0x30, 0x80);
<p dir="auto">SY7088 generates 5V (when EXTEN = 1)<br />
SY7088 output is directly connected to VBUS<br />
VBUS is also connected back into the AXP192 as an input<br />
ACIN is the real USB 5V input</p>
<p dir="auto">So effectively:<br />
BAT → IPSOUT → SY7088 → VBUS → AXP192 → IPSOUT</p>
<p dir="auto">❗ Observed Problem<br />
When running on battery:</p>
<p dir="auto">-Enable 5V output (EXTEN = 1)<br />
-Disconnect USB cable<br />
-Immediately, battery current jumps to ~450 mA<br />
-System enters a self-sustained power loop</p>
<p dir="auto">🔍 Key Observations<br />
EXTEN is correctly set (verified via register dumps, Reg 0x12 bit 6)<br />
VBUS input is permanently enabled (Reg 0x30 = 0x80)<br />
Boost converter behaves normally<br />
Loop appears only when USB is disconnected</p>
<p dir="auto">💡 Root Cause<br />
SY7088 output is physically tied to VBUS<br />
AXP192 does not fully isolate VBUS internally<br />
The supposed N_VBUSEN mechanism does NOT break the electrical path</p>
<p dir="auto">🔥 As a result:<br />
BAT → boost → VBUS → AXP internal path → IPSOUT → boost...</p>
<p dir="auto">This leads to:<br />
continuous energy circulation<br />
high battery drain (~400 mA)<br />
no stable operating point</p>
<p dir="auto">❓ Question to the community<br />
Has anyone:</p>
<li>Observed this behavior on Core2 or similar AXP192 designs?</li>
<li><strong>Found a way to safely use 5V boost to power external accssories from battery without loop?</strong></li>
<p dir="auto">Thank you,<br />
Cheers,<br />
Adrian YO3HJV</p>
]]></description><link>https://community.m5stack.com/topic/8254/m5stack-core2-v1.3-ouroboros-like-power-loop</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 17:30:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8254.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Jun 2026 20:09:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ⚠️ M5Stack Core2 v1.3 -  Ouroboros-like power loop - on Thu, 11 Jun 2026 07:24:05 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/yo3hjv" aria-label="Profile: YO3HJV">@<bdi>YO3HJV</bdi></a></p>
<p dir="auto">yes, I measured the current from the battery with <a href="https://eevblog.store/products/ucurrent-gold-multimeter-adapter" target="_blank" rel="noopener noreferrer nofollow ugc">this mA-meter</a> and also used the AXP192 registers.</p>
]]></description><link>https://community.m5stack.com/post/31063</link><guid isPermaLink="true">https://community.m5stack.com/post/31063</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 11 Jun 2026 07:24:05 GMT</pubDate></item><item><title><![CDATA[Reply to ⚠️ M5Stack Core2 v1.3 -  Ouroboros-like power loop - on Thu, 11 Jun 2026 05:55:56 GMT]]></title><description><![CDATA[<p dir="auto">Did you actually measured the current from the battery with a mA-meter?<br />
I am working directly with the AXP192 registers, I tried something simple with UIFlow but was not to my taste...</p>
<p dir="auto">Here is the project:<br />
Video: <a href="https://www.youtube.com/watch?v=Goauv9xGJqY" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=Goauv9xGJqY</a></p>
<p dir="auto">Adrian</p>
]]></description><link>https://community.m5stack.com/post/31062</link><guid isPermaLink="true">https://community.m5stack.com/post/31062</guid><dc:creator><![CDATA[YO3HJV]]></dc:creator><pubDate>Thu, 11 Jun 2026 05:55:56 GMT</pubDate></item><item><title><![CDATA[Reply to ⚠️ M5Stack Core2 v1.3 -  Ouroboros-like power loop - on Wed, 10 Jun 2026 16:26:01 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/yo3hjv" aria-label="Profile: YO3HJV">@<bdi>YO3HJV</bdi></a></p>
<p dir="auto">glad to hear you figured it out.</p>
<p dir="auto">I was just setting up a test to see if I get this 400 mA power loop too with my M5Core2; but I do not.</p>
<p dir="auto">When I set input mode I see about 82 mA drawn from the battery. When I set output mode I see about 99 mA drawn from the battery. (Note: an LED is connected to the Grove port.)</p>
<p dir="auto">In case your still interested in my UIFlow2 test program. It's in UIFlow2 Project Zone called: <em>M5Core2_Input_Output_Test_UIFlow2.4.6</em></p>
]]></description><link>https://community.m5stack.com/post/31060</link><guid isPermaLink="true">https://community.m5stack.com/post/31060</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 10 Jun 2026 16:26:01 GMT</pubDate></item><item><title><![CDATA[Reply to ⚠️ M5Stack Core2 v1.3 -  Ouroboros-like power loop - on Tue, 09 Jun 2026 20:27:05 GMT]]></title><description><![CDATA[<p dir="auto">Finally, I solved it...<br />
No need for 5V output on 5V_BUS because it came from magnetic base charger.<br />
<strong>Therefore an interlock code was added:</strong><br />
<em>--When 5V from battery is needed for external acc., VBUS== OFF &amp; EXTEN==1;<br />
--When magnetic base charger (or external 5V is applied to Socket Power (J3) on Bottom2, VBUS == INPUT &amp; EXTEN==0.</em></p>
<p dir="auto">This way, the Bottom2 LED's and othe devices are powered with 5V in any situation.</p>
<p dir="auto">Cheers,<br />
Adrian</p>
]]></description><link>https://community.m5stack.com/post/31057</link><guid isPermaLink="true">https://community.m5stack.com/post/31057</guid><dc:creator><![CDATA[YO3HJV]]></dc:creator><pubDate>Tue, 09 Jun 2026 20:27:05 GMT</pubDate></item></channel></rss>
