<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[stick s3 troubleshooting help]]></title><description><![CDATA[<p dir="auto">hi everyone, need help troubleshooting my stick s3 because i tried to burn a firmware from m5burner and now nothing is happening, and the lcd isnt turning on but the green light is on. im new to programming so im not sure what to do. any help would be much appriciated :)</p>
]]></description><link>https://community.m5stack.com/topic/8057/stick-s3-troubleshooting-help</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 05:27:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8057.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Feb 2026 04:19:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to stick s3 troubleshooting help on Fri, 06 Feb 2026 07:21:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timmyprogamsstuff" aria-label="Profile: TimmyProgamsStuff">@<bdi>TimmyProgamsStuff</bdi></a> I'm glad about that. Have a lot of fun</p>
]]></description><link>https://community.m5stack.com/post/30598</link><guid isPermaLink="true">https://community.m5stack.com/post/30598</guid><dc:creator><![CDATA[Mamoulian]]></dc:creator><pubDate>Fri, 06 Feb 2026 07:21:07 GMT</pubDate></item><item><title><![CDATA[Reply to stick s3 troubleshooting help on Thu, 05 Feb 2026 22:34:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mamoulian" aria-label="Profile: Mamoulian">@<bdi>Mamoulian</bdi></a> this worked, thank you so much!!!</p>
]]></description><link>https://community.m5stack.com/post/30597</link><guid isPermaLink="true">https://community.m5stack.com/post/30597</guid><dc:creator><![CDATA[TimmyProgamsStuff]]></dc:creator><pubDate>Thu, 05 Feb 2026 22:34:54 GMT</pubDate></item><item><title><![CDATA[Reply to stick s3 troubleshooting help on Thu, 05 Feb 2026 11:39:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timmyprogamsstuff" aria-label="Profile: TimmyProgamsStuff">@<bdi>TimmyProgamsStuff</bdi></a> maybe try from another computer if you have access - sometimes (at least on older windows, the usb drivers may cause the m5stick to not be recognized).</p>
<p dir="auto">Reboot the computer also (just in case).</p>
]]></description><link>https://community.m5stack.com/post/30589</link><guid isPermaLink="true">https://community.m5stack.com/post/30589</guid><dc:creator><![CDATA[aleekwen]]></dc:creator><pubDate>Thu, 05 Feb 2026 11:39:14 GMT</pubDate></item><item><title><![CDATA[Reply to stick s3 troubleshooting help on Thu, 05 Feb 2026 05:03:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timmyprogamsstuff" aria-label="Profile: TimmyProgamsStuff">@<bdi>TimmyProgamsStuff</bdi></a> Try updating it via webburner in Uiflow2. I couldn't do it either, this helped.</p>
]]></description><link>https://community.m5stack.com/post/30578</link><guid isPermaLink="true">https://community.m5stack.com/post/30578</guid><dc:creator><![CDATA[Mamoulian]]></dc:creator><pubDate>Thu, 05 Feb 2026 05:03:20 GMT</pubDate></item><item><title><![CDATA[Reply to stick s3 troubleshooting help on Wed, 04 Feb 2026 21:02:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robski" aria-label="Profile: robski">@<bdi>robski</bdi></a> i also attempted this and it did work</p>
]]></description><link>https://community.m5stack.com/post/30577</link><guid isPermaLink="true">https://community.m5stack.com/post/30577</guid><dc:creator><![CDATA[TimmyProgamsStuff]]></dc:creator><pubDate>Wed, 04 Feb 2026 21:02:47 GMT</pubDate></item><item><title><![CDATA[Reply to stick s3 troubleshooting help on Wed, 04 Feb 2026 20:09:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aleekwen" aria-label="Profile: aleekwen">@<bdi>aleekwen</bdi></a> unfortunatly this did not work</p>
]]></description><link>https://community.m5stack.com/post/30576</link><guid isPermaLink="true">https://community.m5stack.com/post/30576</guid><dc:creator><![CDATA[TimmyProgamsStuff]]></dc:creator><pubDate>Wed, 04 Feb 2026 20:09:25 GMT</pubDate></item><item><title><![CDATA[Reply to stick s3 troubleshooting help on Wed, 04 Feb 2026 10:05:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timmyprogamsstuff" aria-label="Profile: TimmyProgamsStuff">@<bdi>TimmyProgamsStuff</bdi></a> probably need to be in download mode - the green light needs to be flashing.</p>
<p dir="auto">Press left side button for 2 seconds then plug into usb cable attached to the computer - green light should be flashing.</p>
<p dir="auto">If it was flashed (at least on computer it says it was), disconnect the sticks3 from the computer. If green light is flashing press left button for 6 seconds then press once quickly again - green light should come on then LCD should turn on properly</p>
]]></description><link>https://community.m5stack.com/post/30574</link><guid isPermaLink="true">https://community.m5stack.com/post/30574</guid><dc:creator><![CDATA[aleekwen]]></dc:creator><pubDate>Wed, 04 Feb 2026 10:05:18 GMT</pubDate></item><item><title><![CDATA[Reply to stick s3 troubleshooting help on Wed, 04 Feb 2026 09:37:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timmyprogamsstuff" aria-label="Profile: TimmyProgamsStuff">@<bdi>TimmyProgamsStuff</bdi></a> erase and burn again, just be sure you pick correct firmware for device,</p>
]]></description><link>https://community.m5stack.com/post/30573</link><guid isPermaLink="true">https://community.m5stack.com/post/30573</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Wed, 04 Feb 2026 09:37:39 GMT</pubDate></item></channel></rss>
