<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using 6060 Push]]></title><description><![CDATA[<p dir="auto">Can I connect multiple 6060 push on the same RS485 bus. I see that we can set a device ID, is this stored on the device after a power cycle?</p>
]]></description><link>https://community.m5stack.com/topic/7868/using-6060-push</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Mar 2026 06:26:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7868.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Oct 2025 19:00:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using 6060 Push on Mon, 03 Nov 2025 13:25:46 GMT]]></title><description><![CDATA[<p dir="auto">general rule for RS485 bus is the same baudrate and parity on all slave devices and each device with different slave ID, max 32 devices on one chain</p>
]]></description><link>https://community.m5stack.com/post/30120</link><guid isPermaLink="true">https://community.m5stack.com/post/30120</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 03 Nov 2025 13:25:46 GMT</pubDate></item><item><title><![CDATA[Reply to Using 6060 Push on Mon, 03 Nov 2025 12:33:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/244069">@scroggyg</a> Neither the 6060 push or the STAMP PLC are provided with connectors. The connector type seems to be ht-3.96 4p which I can only find by importing from China. I have some PowerCAN modules which were supplied with this connector, could you please provide these connectors in future?</p>
]]></description><link>https://community.m5stack.com/post/30118</link><guid isPermaLink="true">https://community.m5stack.com/post/30118</guid><dc:creator><![CDATA[scroggyg]]></dc:creator><pubDate>Mon, 03 Nov 2025 12:33:09 GMT</pubDate></item><item><title><![CDATA[Reply to Using 6060 Push on Thu, 30 Oct 2025 19:27:09 GMT]]></title><description><![CDATA[<p dir="auto">I see from the code the ID is stored in EEPROM, but I suspect there can only one device on the bus at a time when the address is set.<br />
Also I suspect I would use an address other than 1, as this is the default address, set when a new device is added</p>
]]></description><link>https://community.m5stack.com/post/30102</link><guid isPermaLink="true">https://community.m5stack.com/post/30102</guid><dc:creator><![CDATA[scroggyg]]></dc:creator><pubDate>Thu, 30 Oct 2025 19:27:09 GMT</pubDate></item></channel></rss>
