<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow TAB5 text scaling]]></title><description><![CDATA[<p dir="auto">I had crested an application usingthe Tough, but I was asked if I could use a larger screen. The application is very simple, but part of it displays a countdown clock (mins : Secs). As the fonts supplied are quite small I had to scale the text. On the Tough (without Scaling) worked fine on the TAB5 when the time changes to 9:59 it shows 9:590 and the zero persists. Is there a way to format the clock in UIFlow so it would show 09:59?</p>
]]></description><link>https://community.m5stack.com/topic/7739/uiflow-tab5-text-scaling</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 01:18:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7739.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Aug 2025 18:35:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow TAB5 text scaling on Thu, 07 Aug 2025 18:40:41 GMT]]></title><description><![CDATA[<p dir="auto">I did a check and set scaling to 1 and the display is properly shown i.e. as 9:59 etc</p>
]]></description><link>https://community.m5stack.com/post/29704</link><guid isPermaLink="true">https://community.m5stack.com/post/29704</guid><dc:creator><![CDATA[scroggyg]]></dc:creator><pubDate>Thu, 07 Aug 2025 18:40:41 GMT</pubDate></item></channel></rss>
