<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tab5 Power up sequence]]></title><description><![CDATA[<p dir="auto">I have 2 Tab5 which I am powering through the Port A I2C connector. They won't power up when power cycled. IF I connect the USB C to aa hub, wait a few seconds, they then power up and stayed powered up. I have previously powered Tough boards through the I2C and it all worked fine.</p>
]]></description><link>https://community.m5stack.com/topic/7702/tab5-power-up-sequence</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 11:08:55 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7702.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Jul 2025 15:49:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tab5 Power up sequence on Thu, 24 Jul 2025 15:42:57 GMT]]></title><description><![CDATA[<p dir="auto">You would need to strap the board to do this. I created a board and getting it made at JLCPCB. The CANPwr board is quite expensive, reasonably enough, it is electrically isolated.</p>
]]></description><link>https://community.m5stack.com/post/29603</link><guid isPermaLink="true">https://community.m5stack.com/post/29603</guid><dc:creator><![CDATA[scroggyg]]></dc:creator><pubDate>Thu, 24 Jul 2025 15:42:57 GMT</pubDate></item><item><title><![CDATA[Reply to Tab5 Power up sequence on Wed, 23 Jul 2025 16:58:21 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/244069">@scroggyg</a></p>
<p dir="auto">well, I think it shouldn't be too difficult to modify the PwrCAN module to provide power to SYSVIN.</p>
<p dir="auto">BTW: the PwrCAN module <a href="https://docs.m5stack.com/en/module/Module13.2-PwrCAN?id=schematics" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a> uses the label <code>HPWR</code> on the connectors and the same label is on the M5Bus. Have you actually measured the <code>HPWR</code> pins of the M5Bus of the PwrCAN module? Maybe they are already connected?</p>
<p dir="auto">Note: I cannot verify this myself as I do not have a PwrCAN module.</p>
]]></description><link>https://community.m5stack.com/post/29596</link><guid isPermaLink="true">https://community.m5stack.com/post/29596</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 23 Jul 2025 16:58:21 GMT</pubDate></item><item><title><![CDATA[Reply to Tab5 Power up sequence on Wed, 23 Jul 2025 11:15:09 GMT]]></title><description><![CDATA[<p dir="auto">I have  now bought both the PWRCAN and the Commu modules, neither apply power to SYSVIN or they do generate 5V on pin 28, which needs to be switched. I am using the TAB5 on a UK double gang plate with a 3D printed Bezel, you can't plug anything into the sides, as they would get removed.<br />
It isn't practical to use the ExtPort2, as I would need to create a custom PCB to connect between the fine pitch fines to add a robust connector, are there any other options to power the TAB5 from behind?<br />
Is there a Comms module ( I what to talk between 2 TAB5s over RS485) with a connector I can power the TAB5 from?<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/post/29591</link><guid isPermaLink="true">https://community.m5stack.com/post/29591</guid><dc:creator><![CDATA[scroggyg]]></dc:creator><pubDate>Wed, 23 Jul 2025 11:15:09 GMT</pubDate></item><item><title><![CDATA[Reply to Tab5 Power up sequence on Wed, 23 Jul 2025 09:09:21 GMT]]></title><description><![CDATA[<p dir="auto">I was wondering about the power-up sequence for the TAB5, and your breakdown really helped clarify things. Especially the part about the 3.3V rail timing—super useful detail.</p>
]]></description><link>https://community.m5stack.com/post/29592</link><guid isPermaLink="true">https://community.m5stack.com/post/29592</guid><dc:creator><![CDATA[samantha_martin]]></dc:creator><pubDate>Wed, 23 Jul 2025 09:09:21 GMT</pubDate></item><item><title><![CDATA[Reply to Tab5 Power up sequence on Tue, 22 Jul 2025 19:22:27 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/244069">@scroggyg</a></p>
<p dir="auto">yes, either that or provide 5V via <code>5VIN</code>.</p>
]]></description><link>https://community.m5stack.com/post/29581</link><guid isPermaLink="true">https://community.m5stack.com/post/29581</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 22 Jul 2025 19:22:27 GMT</pubDate></item><item><title><![CDATA[Reply to Tab5 Power up sequence on Tue, 22 Jul 2025 18:37:29 GMT]]></title><description><![CDATA[<p dir="auto">I assume then the correct way to do this would be to use ExtPort2 and connect up to 12V through HVIN?</p>
]]></description><link>https://community.m5stack.com/post/29580</link><guid isPermaLink="true">https://community.m5stack.com/post/29580</guid><dc:creator><![CDATA[scroggyg]]></dc:creator><pubDate>Tue, 22 Jul 2025 18:37:29 GMT</pubDate></item><item><title><![CDATA[Reply to Tab5 Power up sequence on Wed, 23 Jul 2025 16:51:53 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/244069">@scroggyg</a></p>
<p dir="auto">M5Tab5 port A is powered through a switch (U26) which when turned on lets <code>SYS_INT5V</code> through to <code>SYS_EXT5VO</code>. The switch is enabled via <code>EXT5V_EN</code> coming from one of the port expanders (U6).</p>
<p dir="auto">In other words, M5Tab5 <strong>cannot</strong> be turned on via port A as initially the switch is off.</p>
<p dir="auto">See schematic <a href="https://docs.m5stack.com/en/core/Tab5?id=schematics" target="_blank" rel="noopener noreferrer nofollow ugc">here</a> and/or the backside of M5Tab5.</p>
]]></description><link>https://community.m5stack.com/post/29579</link><guid isPermaLink="true">https://community.m5stack.com/post/29579</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 23 Jul 2025 16:51:53 GMT</pubDate></item></channel></rss>
