<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Title (English): Fixing M5Burner on macOS (Apple Silicon) - Manual Patch + Instructions Título (Español): Solución para M5Burner en macOS (Apple Silicon) - Parche manual + Instrucciones]]></title><description><![CDATA[<p dir="auto">ENGLISH INSTRUCTIONS</p>
<p dir="auto">If M5Burner doesn't work on your new Mac (especially with macOS 15.x or Apple Silicon M4/M3), and it crashes on startup or doesn't load any firmware, here's how to fix it manually.</p>
<p dir="auto">🔄 Symptom</p>
<p dir="auto">M5Burner launches but shows errors like invalid signature: 0x54454d3c</p>
<p dir="auto">Missing folders like firmware/ or dat/ inside the app</p>
<p dir="auto">JavaScript or unzipper errors in Terminal</p>
<p dir="auto">🔧 Manual Fix Steps</p>
<p dir="auto">Download M5Burner (latest version)From the official site:<a href="https://m5stack.com/pages/download" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/pages/download</a></p>
<p dir="auto">Fix permissions (required for macOS Gatekeeper)</p>
<p dir="auto">xattr -c /Applications/M5Burner.app</p>
<p dir="auto">Download the manual patch (missing folders)GitHub repo:<a href="https://github.com/neusmstack/M5Burner_patch" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/neusmstack/M5Burner_patch</a></p>
<p dir="auto">Or direct download of the ZIP file:<a href="https://github.com/neusmstack/M5Burner_patch/raw/main/M5Burner_patch_files.zip" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/neusmstack/M5Burner_patch/raw/main/M5Burner_patch_files.zip</a></p>
<p dir="auto">Unzip the file and copy the firmware/ and dat/ folders into this path:</p>
<p dir="auto">/Applications/M5Burner.app/Contents/Resources/packages/</p>
<p dir="auto">Launch M5Burner again and everything should work fine:</p>
<p dir="auto">Firmware list will appear</p>
<p dir="auto">You can burn and configure devices</p>
<p dir="auto">🇪🇸 INSTRUCCIONES EN ESPAÑOL</p>
<p dir="auto">Si M5Burner no funciona correctamente en tu nuevo Mac (especialmente con macOS 15.x o Apple Silicon M4/M3), y se bloquea al arrancar o no carga firmwares, aquí tienes la solución manual.</p>
<p dir="auto">🔄 Síntomas</p>
<p dir="auto">M5Burner se inicia pero da errores como invalid signature: 0x54454d3c</p>
<p dir="auto">No aparecen las carpetas firmware/ o dat/ en la app</p>
<p dir="auto">Aparecen errores JavaScript en el Terminal</p>
<p dir="auto">🔧 Pasos para arreglarlo manualmente</p>
<p dir="auto">Descarga la última versión de M5BurnerDesde la web oficial:<a href="https://m5stack.com/pages/download" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/pages/download</a></p>
<p dir="auto">Corrige los permisos de seguridad (Gatekeeper)</p>
<p dir="auto">Descarga el parche manual (carpetas faltantes)Repositorio GitHub:<a href="https://github.com/neusmstack/M5Burner_patch" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/neusmstack/M5Burner_patch</a></p>
<p dir="auto">O descarga directa del archivo ZIP:<a href="https://github.com/neusmstack/M5Burner_patch/raw/main/M5Burner_patch_files.zip" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/neusmstack/M5Burner_patch/raw/main/M5Burner_patch_files.zip</a></p>
<p dir="auto">Descomprime el archivo y copia las carpetas firmware/ y dat/ dentro de esta ruta:</p>
<p dir="auto">Vuelve a abrir M5Burner y todo debería funcionar correctamente:</p>
<p dir="auto">Aparece la lista de firmware</p>
<p dir="auto">Puedes grabar y configurar tus dispositivos</p>
<p dir="auto">If this worked for you, please leave a like or comment in the forum to help others! 😊Si esto te funcionó, deja un like o comentario en el foro para ayudar a otros. 😊</p>
]]></description><link>https://community.m5stack.com/topic/7582/title-english-fixing-m5burner-on-macos-apple-silicon-manual-patch-instructions-título-español-solución-para-m5burner-en-macos-apple-silicon-parche-manual-instrucciones</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 01:22:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7582.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 May 2025 09:31:22 GMT</pubDate><ttl>60</ttl></channel></rss>
