<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core 1 Guru Pannic.]]></title><description><![CDATA[<p dir="auto">I'm testing the ENVPro and M5Station for a video guide but between 30 mins and an hour the Station resets with the rolling error log:</p>
<pre><code>E (2903049) mqtt_client: Error create mqtt task
E (2918550) mqtt_client: esp_mqtt_set_config(415): Memory exhausted
E (2918551) event: event_loop was NULL
A fatal error occurred. The crash dump printed below may be used to help
determine what caused it. If you are not already running the most recent
version of MicroPython, consider upgrading. New versions often fix bugs.
To learn more about how to debug and/or report this crash visit the wiki
page at: https://github.com/micropython/micropython/wiki/ESP32-debugging
MPY version : v1.24.0-dirty on 2025-01-18
IDF version : v5.2.2-dirty
Machine     : M5STACK Station with ESP32
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core  1 register dump:
PC      : 0x4016dee7  PS      : 0x00060030  A0      : 0x8010d60f  A1      : 0x3ffd24b0
A2      : 0x3ffe1d40  A3      : 0xffffffff  A4      : 0x40111be4  A5      : 0x00000000
A6      : 0x3f4073a4  A7      : 0x00000000  A8      : 0x00000000  A9      : 0x3ffd2460
A10     : 0x002c8356  A11     : 0x3f435f7c  A12     : 0xffffffff  A13     : 0x40111be4
A14     : 0x00000000  A15     : 0x00001000  SAR     : 0x0000000a  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000  LBEG    : 0x40083b51  LEND    : 0x40083b59  LCOUNT  : 0x00000027
Backtrace: 0x4016dee4:0x3ffd24b0 0x4010d60c:0x3ffd24d0 0x401125a1:0x3ffd26a0
ELF file SHA256: 041d1f64b
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:5128
load:0x40078000,len:15884
ho 0 tail 12 room 4
load:0x40080400,len:4
load:0x40080404,len:3696
entry 0x400805c4
       _  __ _
 _   _(_)/ _| | _____      __
| | | | | |_| |/ _ \ \ /\ / /
| |_| | |  _| | (_) \ V  V /
 \__,_|_|_| |_|\___/ \_/\_/  V2.2.1
E (2100) i2c: i2c driver install error
E (2116) time: The current date/time in Shanghai is: Fri Nov 30 20:13:11 2001
E (2978) i2c: i2c driver install error
E (431156) mqtt_client: No PING_RESP, disconnected
E (542578) mqtt_client: No PING_RESP, disconnected
E (573085) esp-tls: [sock=54] select() timeout
E (573085) transport_base: Failed to open a new connection: 32774
E (573086) mqtt_client: Error transport connect
E (573091) M5Things: Last error reported from esp-tls: 0x8006
E (610673) mqtt_client: No PING_RESP, disconnected
E (642541) mqtt_client: No PING_RESP, disconnected
E (764053) mqtt_client: No PING_RESP, disconnected
<p dir="auto">I've tried enabling gc (garbage collection) to clear the memory each loop but it make no difference  and if you check out my code I don't have any MQTT function enabled!</p>
<pre><code>import os, sys, io
import M5
from M5 import *
from hardware import I2C
from hardware import Pin
from unit import ENVPROUnit
from hardware import RGB
import time
label0 = None
rect0 = None
label3 = None
label1 = None
label2 = None
i2c0 = None
rgb = None
envpro_0 = None
def setup():
  global label0, rect0, label3, label1, label2, i2c0, rgb, envpro_0
  M5.begin()
  label0 = Widgets.Label("label0", -3, 10, 1.0, 0xffffff, 0x000000, Widgets.FONTS.DejaVu18)
  rect0 = Widgets.Rectangle(-1, 111, 30, 20, 0x000000, 0xffffff)
  label3 = Widgets.Label("label3", -1, 60, 1.0, 0xffffff, 0x000000, Widgets.FONTS.DejaVu18)
  label1 = Widgets.Label("label1", -1, 35, 1.0, 0xffffff, 0x000000, Widgets.FONTS.DejaVu18)
  label2 = Widgets.Label("label2", -1, 87, 1.0, 0xffffff, 0x000000, Widgets.FONTS.DejaVu18)
  import gc
  i2c0 = I2C(0, scl=Pin(33), sda=Pin(32), freq=100000)
  envpro_0 = ENVPROUnit(i2c0)
  rgb = RGB()
  rect0.setColor(color=0x000000, fill_c=0x33cc00)
def loop():
  M5.update()
  gc.collect()
  label0.setText(str((str('Temperature: ') + str((envpro_0.get_temperature())))))
  label1.setText(str((str('Pressure: ') + str((envpro_0.get_pressure())))))
  label2.setText(str((str('Humidity: ') + str((envpro_0.get_humidity())))))
  label3.setText(str((str('Gas RES: ') + str((envpro_0.get_gas_resistance())))))
  if (envpro_0.get_humidity()) &gt; 60:
    rgb.set_color(6, 0x3333ff)
    rect0.setColor(color=0x330033, fill_c=0x3333ff)
  else:
    rgb.set_color(6, 0x33cc00)
    rect0.setColor(color=0x330033, fill_c=0x33cc00)
  rect0.setSize(w=((int(envpro_0.get_humidity())) * 2), h=20)
  time.sleep(5)
if __name__ == '__main__':
  try:
    setup()
    while True:
      loop()
    try:
      print_error_msg(e)
    except ImportError:
<p dir="auto">I'm at a loss here and wondering if this is a firmware issue.</p>
]]></description><link>https://community.m5stack.com/topic/7347/core-1-guru-pannic</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 08:52:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7347.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Mar 2025 06:29:50 GMT</pubDate><ttl>60</ttl></channel></rss>
