<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RollerCan &quot;virtual detents&quot; and position readback question(s)]]></title><description><![CDATA[<p dir="auto">Hi - I'm using RollerCan motors for a robot teleop setup and have two questions related to the encoder functionality:</p>
<li>
<p dir="auto">In the documentation its mentioned (somewhere) that the RollerCan relies on open source projects including <a href="https://github.com/scottbez1/smartknob" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/scottbez1/smartknob</a> - which I assume is how the clicky detent behavior is implemented when the motor is in encoder mode.  Are there any methods to set or modify the detent behaviors?</p>
</li>
<li>
<p dir="auto">For the "rollercan_0.get_motor_position_readback()" method, just wanted to confirm the value returned is degrees - it seems to be, but I don't see that documented anywhere.</p>
</li>
<p dir="auto">Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/7260/rollercan-virtual-detents-and-position-readback-question-s</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 01:17:52 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7260.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Feb 2025 20:57:03 GMT</pubDate><ttl>60</ttl></channel></rss>
