<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CORE, RS485 and 2x2RELAY...]]></title><description><![CDATA[<p dir="auto">I have a simple code that displays the date, time, temperature and humidity data acquired by an RS485 device (XY-MD04), but the console keeps displaying the following messages:</p>
<p dir="auto">E (18258813) mqtt_client: esp_mqtt_client_init(800): Memory exhausted<br />
E (18258814) mqtt_client: Client was not initialized<br />
E (18258815) mqtt_client: Client was not initialized</p>
<p dir="auto">I have a CORE, 2x 2RELAY modules, an M5GO module (Port C), an RS485 converter via Port C and an XY-MD04 humidity and temperature sensor via RS485.</p>
<p dir="auto">I'm not even using MQTT...</p>
<p dir="auto">How do I know the size of my CORE's memory?<br />
What is the size of the code I can use, and how do I know it?<br />
My project is based on activating the relays based on RS485 data readings and timing (RTC). With the same code, sometimes it works, sometimes it presents execution errors.</p>
<p dir="auto">I am very, very grateful for any help!</p>
]]></description><link>https://community.m5stack.com/topic/6988/core-rs485-and-2x2relay</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 03:38:11 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6988.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Nov 2024 16:17:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CORE, RS485 and 2x2RELAY... on Sun, 17 Nov 2024 10:28:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> thank you!</p>
]]></description><link>https://community.m5stack.com/post/27063</link><guid isPermaLink="true">https://community.m5stack.com/post/27063</guid><dc:creator><![CDATA[cryptospok]]></dc:creator><pubDate>Sun, 17 Nov 2024 10:28:31 GMT</pubDate></item><item><title><![CDATA[Reply to CORE, RS485 and 2x2RELAY... on Sat, 16 Nov 2024 17:18:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cryptospok" aria-label="Profile: cryptospok">@<bdi>cryptospok</bdi></a></p>
<p dir="auto"><a href="https://docs.m5stack.com/en/core/basic_v2.7" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/core/basic_v2.7</a></p>
<p dir="auto">ESP32-D0WDQ6-V3	<br />
520KB SRAM,<br />
Flash	16MB</p>
]]></description><link>https://community.m5stack.com/post/27060</link><guid isPermaLink="true">https://community.m5stack.com/post/27060</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sat, 16 Nov 2024 17:18:30 GMT</pubDate></item><item><title><![CDATA[Reply to CORE, RS485 and 2x2RELAY... on Sat, 16 Nov 2024 16:18:55 GMT]]></title><description><![CDATA[<p dir="auto">Thius is the code:</p>
<p dir="auto"><img src="/assets/uploads/files/1731773931617-uiflow2_block_1731773869116.png" alt="uiflow2_block_1731773869116.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/27058</link><guid isPermaLink="true">https://community.m5stack.com/post/27058</guid><dc:creator><![CDATA[cryptospok]]></dc:creator><pubDate>Sat, 16 Nov 2024 16:18:55 GMT</pubDate></item></channel></rss>
