<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core with multiple UARTs]]></title><description><![CDATA[<p dir="auto">I'm looking for a device with at least two UARTs expose. I understand the S3 has three UARTs but I can't tell if these can be muxed to any of the additional pins.</p>
<p dir="auto">The M5stack docs seems to suggest only one of the ports supports UART. However the datasheet suggests you can pin mux any signal to any pin, so I presume I can break out the uart to any pin/ports on the m5stack S3 devices.</p>
<p dir="auto">For example, the CoreS3 could have 2 UARTs broken out onto any two of the ports A, B or C. Is this true?<br />
Is there any limitation on the software stacks in exposing the uarts?</p>
]]></description><link>https://community.m5stack.com/topic/6961/core-with-multiple-uarts</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Mar 2026 05:57:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6961.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Nov 2024 23:46:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core with multiple UARTs on Wed, 06 Nov 2024 08:33:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/179589">@WigglerAway</a> You will need to check out the documentation on the M5Stack website for the exact pins but by default UART1 is broken out to the blue port and UART 2 is broken out to the MBUS connector.</p>
<p dir="auto">The CoreMP135 has UART1 broken out to the blue port, UART2 to the MBUS and UART6 broken out to the RS485 connector.</p>
]]></description><link>https://community.m5stack.com/post/26973</link><guid isPermaLink="true">https://community.m5stack.com/post/26973</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 06 Nov 2024 08:33:06 GMT</pubDate></item></channel></rss>
