<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Power needed]]></title><description><![CDATA[<p dir="auto">Is there any way to get the 5V connecter to supply power to a motion sensor using the M5Stamp?</p>
]]></description><link>https://community.m5stack.com/topic/6856/power-needed</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 21:10:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6856.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 02 Oct 2024 19:21:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Power needed on Fri, 04 Oct 2024 13:04:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> Today I will try connecting up the 5V piece to it . Thanks for the help</p>
]]></description><link>https://community.m5stack.com/post/26608</link><guid isPermaLink="true">https://community.m5stack.com/post/26608</guid><dc:creator><![CDATA[leaguen]]></dc:creator><pubDate>Fri, 04 Oct 2024 13:04:12 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Fri, 04 Oct 2024 01:37:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leaguen" aria-label="Profile: leaguen">@<bdi>leaguen</bdi></a> said in <a href="/post/26604">Power needed</a>:<br />
The  HC-SR501 is an old Arduino era sensor designed for 5V. Many people use it with an ESP32 3.3V with success.<br />
But yeah, putting 5V to either 5V pin will power the ESP32 @ 3.3V and 3.3V will appear at the side 3.3V pin. And 5V will appear on the Grove 5V pin.<br />
Very clever design.</p>
]]></description><link>https://community.m5stack.com/post/26605</link><guid isPermaLink="true">https://community.m5stack.com/post/26605</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Fri, 04 Oct 2024 01:37:15 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Fri, 04 Oct 2024 01:05:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> Gotcha so If I give 5v to the 5V connecter the bottom 5v connecter will output 5V (I am rereading this and god I hope you understand that.) and the ir sensor is a HC-SR501</p>
]]></description><link>https://community.m5stack.com/post/26604</link><guid isPermaLink="true">https://community.m5stack.com/post/26604</guid><dc:creator><![CDATA[leaguen]]></dc:creator><pubDate>Fri, 04 Oct 2024 01:05:04 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Thu, 03 Oct 2024 20:00:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leaguen" aria-label="Profile: leaguen">@<bdi>leaguen</bdi></a> Great, so you are supplying it with 3.3V.<br />
If you supply 5V through the 5V connector on the left side, 5V will also be at the bottom 'Grove' connector...and the 5V will be stepped down to 3.3 for the Stamp ESP32 ckt...and 3.3 will be available at the 3.3v pin on the other side.<br />
Win-win.<br />
Do you have a part number for the IR sensor?<br />
I would like to check it out, maybe runs on 3.3V? (Despite the rating)</p>
]]></description><link>https://community.m5stack.com/post/26603</link><guid isPermaLink="true">https://community.m5stack.com/post/26603</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Thu, 03 Oct 2024 20:00:13 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Thu, 03 Oct 2024 18:37:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> I have it powered off of the 3v3 connector, and its an IR sensor to detect motion. operation voltage of 5V-20V.</p>
]]></description><link>https://community.m5stack.com/post/26601</link><guid isPermaLink="true">https://community.m5stack.com/post/26601</guid><dc:creator><![CDATA[leaguen]]></dc:creator><pubDate>Thu, 03 Oct 2024 18:37:35 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Wed, 02 Oct 2024 20:37:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leaguen" aria-label="Profile: leaguen">@<bdi>leaguen</bdi></a> How do you power the Stamp now? If you input 5V to either 5V pin, the Stamp will get 3.3V and the other pin will be 5V.<br />
The Docs are here:<br />
<a href="https://docs.m5stack.com/en/core/stamp_pico" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/core/stamp_pico</a><br />
What sensor needs 5V? (just curious as I am almost exclusively 3.3V now)</p>
]]></description><link>https://community.m5stack.com/post/26583</link><guid isPermaLink="true">https://community.m5stack.com/post/26583</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 02 Oct 2024 20:37:01 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Wed, 02 Oct 2024 20:26:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> gotcha, so I need to find another way to power the sensor.</p>
]]></description><link>https://community.m5stack.com/post/26581</link><guid isPermaLink="true">https://community.m5stack.com/post/26581</guid><dc:creator><![CDATA[leaguen]]></dc:creator><pubDate>Wed, 02 Oct 2024 20:26:11 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Wed, 02 Oct 2024 20:11:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leaguen" aria-label="Profile: leaguen">@<bdi>leaguen</bdi></a> OK! Curious thing about the Stamp pico is that 3.3V in from the programmer device is all that is available at the ""5V"" pins!</p>
<p dir="auto">There is no Boost regulator on this one.</p>
]]></description><link>https://community.m5stack.com/post/26579</link><guid isPermaLink="true">https://community.m5stack.com/post/26579</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 02 Oct 2024 20:11:49 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Wed, 02 Oct 2024 19:58:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> Got it, I soldered a lead to the 5V connector in the picture, but it wasn't supplying power, so I thought the bottom one would be no different. Also I bought mine in a pack of 5 so it does not come with one.<img src="/assets/uploads/files/1727899076372-c3a907a7-1b33-4221-81d0-356032e7bf27-image.png" alt="c3a907a7-1b33-4221-81d0-356032e7bf27-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/26578</link><guid isPermaLink="true">https://community.m5stack.com/post/26578</guid><dc:creator><![CDATA[leaguen]]></dc:creator><pubDate>Wed, 02 Oct 2024 19:58:00 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Wed, 02 Oct 2024 19:52:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leaguen" aria-label="Profile: leaguen">@<bdi>leaguen</bdi></a> You can solder directly to the Stamp Pico or install a Grove connector, I think it came with one?</p>
]]></description><link>https://community.m5stack.com/post/26577</link><guid isPermaLink="true">https://community.m5stack.com/post/26577</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 02 Oct 2024 19:52:28 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Wed, 02 Oct 2024 19:49:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> No, the pico mini<img src="/assets/uploads/files/1727898582335-a2ae01c1-ce19-4a9d-bc53-2c86592f5d47-image.png" alt="a2ae01c1-ce19-4a9d-bc53-2c86592f5d47-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/26576</link><guid isPermaLink="true">https://community.m5stack.com/post/26576</guid><dc:creator><![CDATA[leaguen]]></dc:creator><pubDate>Wed, 02 Oct 2024 19:49:48 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Wed, 02 Oct 2024 19:48:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leaguen" aria-label="Profile: leaguen">@<bdi>leaguen</bdi></a> What stamp? Do you mean the USB?</p>
]]></description><link>https://community.m5stack.com/post/26575</link><guid isPermaLink="true">https://community.m5stack.com/post/26575</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 02 Oct 2024 19:48:52 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Wed, 02 Oct 2024 19:47:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> Thanks can I solder directly to the 5v connector at the bottom of the stamp or do I need the groove connector for that?</p>
]]></description><link>https://community.m5stack.com/post/26574</link><guid isPermaLink="true">https://community.m5stack.com/post/26574</guid><dc:creator><![CDATA[leaguen]]></dc:creator><pubDate>Wed, 02 Oct 2024 19:47:31 GMT</pubDate></item><item><title><![CDATA[Reply to Power needed on Wed, 02 Oct 2024 19:45:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leaguen" aria-label="Profile: leaguen">@<bdi>leaguen</bdi></a> You can solder a grove connector to the side of the Stamp and get Gnd, 5V, and two GPIO that can be used for I2C sensors.</p>
]]></description><link>https://community.m5stack.com/post/26573</link><guid isPermaLink="true">https://community.m5stack.com/post/26573</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 02 Oct 2024 19:45:15 GMT</pubDate></item></channel></rss>
