<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SIM800L power supply]]></title><description><![CDATA[<p dir="auto">SIM800l problem with voltage. Modul SIM800L work with 3,4-4,4 VDC but M5 product give 4,9V. At this voltage the module does not connect to the network.  To change it , I used MP2307DN step-down converter, but it is hard to set optimal voltage. I haved luck and set on 3,85V. <img src="/assets/uploads/files/1723140157058-20240808_193957.jpg" alt="20240808_193957.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/6689/sim800l-power-supply</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 22:27:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6689.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Aug 2024 14:49:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SIM800L power supply on Fri, 09 Aug 2024 15:08:05 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/kris" aria-label="Profile: Kris">@<bdi>Kris</bdi></a></p>
<p dir="auto">thank you for sharing your solution. With 5 V supplied from an external power supply I actually measure about 4.7 V going to the SIM800L due to the voltage drop of diode D1. But yes, that is still out of the specified VBAT absolute maximum rating of 4.5 V.</p>
]]></description><link>https://community.m5stack.com/post/26042</link><guid isPermaLink="true">https://community.m5stack.com/post/26042</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 09 Aug 2024 15:08:05 GMT</pubDate></item></channel></rss>
