<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m5dial: wifi not work when rfid is enabled]]></title><description><![CDATA[<p dir="auto">even a simple code like this can raise my problem</p>
<pre><code>//connect to WiFi
Serial.printf("Connecting to %s ", ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500); Serial.print(".");
<p dir="auto">Serial.println(" CONNECTED");</p>
<p dir="auto">with this config setting everything is ok</p>
<pre><code>M5Dial.begin(cfg, false, false);
<p dir="auto">but if i enable rfid</p>
<pre><code>M5Dial.begin(cfg, false, true);
<p dir="auto">m5dial can connect only once to my wifi network, i have a fritzbox router</p>
<p dir="auto">any idea?</p>
]]></description><link>https://community.m5stack.com/topic/6628/m5dial-wifi-not-work-when-rfid-is-enabled</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 10:26:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6628.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Jul 2024 08:43:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m5dial: wifi not work when rfid is enabled on Tue, 11 Mar 2025 08:39:38 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/234883">@gadgetguy</a></p>
<p dir="auto">I can confirm that enabling RFID prevents M5Dial from connecting to WiFi.</p>
<p dir="auto">After enabling RFID in <code>M5Dial.begin(cfg, true, true)</code>, try <code>M5Dial.Rfid.PCD_AntennaOff()</code> to temporarily disable RFID while using WiFi, then after disconnecting from WiFi enable RFID again with <code>M5Dial.Rfid.PCD_AntennaOn()</code>.</p>
]]></description><link>https://community.m5stack.com/post/28460</link><guid isPermaLink="true">https://community.m5stack.com/post/28460</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 11 Mar 2025 08:39:38 GMT</pubDate></item><item><title><![CDATA[Reply to m5dial: wifi not work when rfid is enabled on Mon, 10 Mar 2025 22:49:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/232827">@Slarck</a> So I have hooked up a 12V power supply to the power connector (2pin green).  It doesn't help, I can't connect to the Wifi when the RFID is enabled.</p>
<p dir="auto">Any ideas? I tried turning the RFID off when I connect to the wifi</p>
<p dir="auto">M5Dial.begin(cfg, true, false); // enable encoder, disenable RFID</p>
<p dir="auto">but once I turn on the RFID, it doesn't seem that turning it off enables the Wifi.</p>
<p dir="auto">If I never enable the RFID, then I can connect to the Router, so I don't think my router or channel is an issue.</p>
<p dir="auto">Any other ideas welcome.</p>
]]></description><link>https://community.m5stack.com/post/28450</link><guid isPermaLink="true">https://community.m5stack.com/post/28450</guid><dc:creator><![CDATA[gadgetguy]]></dc:creator><pubDate>Mon, 10 Mar 2025 22:49:02 GMT</pubDate></item><item><title><![CDATA[Reply to m5dial: wifi not work when rfid is enabled on Sat, 22 Feb 2025 15:22:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/232827">@Slarck</a> Thanks will look into those. I don't need them simultaneously, I tried turning the RFID on/off, but once I turn it on (after doing a server packet test), even if I turned it off Wifi still doesn't work.</p>
]]></description><link>https://community.m5stack.com/post/28303</link><guid isPermaLink="true">https://community.m5stack.com/post/28303</guid><dc:creator><![CDATA[gadgetguy]]></dc:creator><pubDate>Sat, 22 Feb 2025 15:22:18 GMT</pubDate></item><item><title><![CDATA[Reply to m5dial: wifi not work when rfid is enabled on Thu, 20 Feb 2025 14:33:51 GMT]]></title><description><![CDATA[<p dir="auto">The RFID module might be interfering with the WiFi signal. Try using a different power source or check if the RFID is drawing too much current and test with a different router or 2.4GHz channel.</p>
]]></description><link>https://community.m5stack.com/post/28277</link><guid isPermaLink="true">https://community.m5stack.com/post/28277</guid><dc:creator><![CDATA[Slarck]]></dc:creator><pubDate>Thu, 20 Feb 2025 14:33:51 GMT</pubDate></item><item><title><![CDATA[Reply to m5dial: wifi not work when rfid is enabled on Tue, 18 Feb 2025 00:29:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/136739">@studiosacchetti</a> Did you ever solve this issue? I am now having exactly the same issue.</p>
]]></description><link>https://community.m5stack.com/post/28255</link><guid isPermaLink="true">https://community.m5stack.com/post/28255</guid><dc:creator><![CDATA[gadgetguy]]></dc:creator><pubDate>Tue, 18 Feb 2025 00:29:34 GMT</pubDate></item></channel></rss>
