<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Measuring the Water Temperature]]></title><description><![CDATA[<p dir="auto">Because I was not satisfied with the information about the water temperature of the Baltic Sea during a past vacation stay, I built a thermometer with M5Stack components and a remote temperature sensor and presented it in a blog post. With the remote DS18B20 temperature sensor, I measured the water temperature at a depth of one meter.</p>
<p dir="auto">Now the vacations are approaching again, and the message from the BSH still shows very cool water at the end of May.</p>
<p dir="auto">I have extended the presented thermometer to follow the water temperature changes and be immune from bigger surprises.<br />
Because of the slightly larger display, I replaced the M5StickC with an M5StickC+ and used an M5StickC 18650C to increase the battery capacity. In addition, the thermometer is much easier to handle.</p>
<p dir="auto">To have the readings available on my mobile phone, I use it as a mobile hotspot and send the readings from the M5StickC+ via WiFi to the mobile phone, which then sends the data to the Pushover server. From there, the data is then distributed to the selected end devices.</p>
<p dir="auto">This setup won't affect the water temperature, but I can record it in writing. And if it stays that cold, then I can document my heroism.</p>
<p dir="auto">The link to the original post in German is <a href="https://wordpress.com/post/ckblog2016.net/4227" target="_blank" rel="noopener noreferrer nofollow ugc">https://wordpress.com/post/ckblog2016.net/4227</a></p>
]]></description><link>https://community.m5stack.com/topic/5391/measuring-the-water-temperature</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 19:37:56 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5391.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Jun 2023 18:06:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Measuring the Water Temperature on Fri, 19 Jan 2024 10:34:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ckuehnel" aria-label="Profile: ckuehnel">@<bdi>ckuehnel</bdi></a> said in <a href="/post/21202">Measuring the Water Temperature</a>:</p>
<p dir="auto">Because I was not satisfied with the information about the water temperature of the Baltic Sea during a past vacation stay, I built a thermometer with M5Stack components and a remote temperature sensor and presented it in a blog post. With the remote DS18B20 temperature sensor, I measured the water temperature at a depth of one meter.<br />
Now the vacations are approaching again, and the message from the BSH still shows very cool water at the end of May.<br />
Because of the slightly larger display, I replaced the M5StickC with an M5StickC+ and used an M5StickC 18650C to increase the battery capacity. In addition, the thermometer is much easier to handle.<br />
To have the readings available on my mobile phone, I use it as a mobile hotspot and send the readings from the M5StickC+ via WiFi to the mobile phone, which then sends the data to the Pushover server. From there, the data is then distributed to the selected end devices.<br />
<p dir="auto">That's really impressive! Building your own thermometer to monitor the Baltic Sea's water temperature is a unique approach. Upgrading to the M5StickC+ with an M5StickC 18650C for more battery capacity sounds like a smart move. And the data transmission setup using your mobile phone as a hotspot and Pushover server is clever! It may not change the water temperature, but it's great for keeping records. Thanks for sharing, and here's the temperature converter link you mentioned: <a href="https://oneconvert.com/unit-converters/temperature-converter/fahrenheit-to-celsius" target="_blank" rel="noopener noreferrer nofollow ugc">temperature converter</a>. Good luck with your upcoming vacation and documenting your heroism! 😄🌊🌡️</p>
]]></description><link>https://community.m5stack.com/post/23400</link><guid isPermaLink="true">https://community.m5stack.com/post/23400</guid><dc:creator><![CDATA[cake00]]></dc:creator><pubDate>Fri, 19 Jan 2024 10:34:47 GMT</pubDate></item><item><title><![CDATA[Reply to Measuring the Water Temperature on Thu, 15 Jun 2023 05:33:20 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for sharing.<br />
Have you considered adding one of these <a href="https://shop.m5stack.com/products/m5stamp-cat-m-module-sim7080g" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/m5stamp-cat-m-module-sim7080g</a><br />
to act and the mobile phone so it can send the data out with a server without needing to take a mobile phone to it?</p>
]]></description><link>https://community.m5stack.com/post/21204</link><guid isPermaLink="true">https://community.m5stack.com/post/21204</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 15 Jun 2023 05:33:20 GMT</pubDate></item></channel></rss>
