<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fire is dead ... how can this be solved ?]]></title><description><![CDATA[<p dir="auto">Hello<br />
I have received my new M5Stack Fire.<br />
On the Arduino IDE, I load one of the Examples (M5Stack Fire) &gt; ESP32&gt; Time&gt; SimpleTime.<br />
I compiled the SimpleTime to be displayed on the screen<br />
The compile was fine done., load them up via the USB into the M5STack Fire. ...since them nothing happened.<br />
Display is black ...no start is possible nothing is working any more :-(<br />
I tried then to load the UIFlow-Desktop-IDE no connection via COM3.<br />
Since then the RED LED is just on :-( no Python Menu is comming up just nothing<br />
My question is how get I back my M5Stack Fire working?<br />
Does the Hard RESET may be solve my "dead M5Stack Fire" ?<br />
Thanks a lot for your assistance<br />
Urmel</p>
]]></description><link>https://community.m5stack.com/topic/5244/fire-is-dead-how-can-this-be-solved</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 05:51:23 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5244.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 23 Apr 2023 14:34:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fire is dead ... how can this be solved ? on Thu, 21 Mar 2024 07:53:33 GMT]]></title><description><![CDATA[<p dir="auto">SOLUTION<br />
I found the solution:<br />
You need to follow these steps</p>
<li>Remove all modules, leaving only the host</li>
<li>Then try to lower the baud rate when burning</li>
<li>If there are wires, you can short-circuit G0-GND before powering on the device and then power on again.<img src="/assets/uploads/files/1711007607197-432299571_430472252787300_1867478767739245481_n-resized.jpg" alt="0_1711007605157_432299571_430472252787300_1867478767739245481_n.jpg" class=" img-fluid img-markdown" /></li>
]]></description><link>https://community.m5stack.com/post/24495</link><guid isPermaLink="true">https://community.m5stack.com/post/24495</guid><dc:creator><![CDATA[mylesdebaerdemaeker]]></dc:creator><pubDate>Thu, 21 Mar 2024 07:53:33 GMT</pubDate></item><item><title><![CDATA[Reply to Fire is dead ... how can this be solved ? on Tue, 19 Mar 2024 17:48:21 GMT]]></title><description><![CDATA[<p dir="auto">You have installed the esp32 libraries and board definitions along with espidf?<br />
Have you selected the correct board type and communication speed have you made sure the example was actually for the fire and not another core?</p>
<p dir="auto">Have you erased the core using M5Burner first?<br />
Have you watched or read any of my guides or the many other guides on programming a core?</p>
]]></description><link>https://community.m5stack.com/post/24441</link><guid isPermaLink="true">https://community.m5stack.com/post/24441</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 19 Mar 2024 17:48:21 GMT</pubDate></item><item><title><![CDATA[Reply to Fire is dead ... how can this be solved ? on Tue, 19 Mar 2024 14:28:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi I have the same issue and get this error when I try to upload<br />
Sketch uses 404741 bytes (6%) of program storage space. Maximum is 6553600 bytes.<br />
Global variables use 23136 bytes (0%) of dynamic memory, leaving 4498848 bytes for local variables. Maximum is 4521984 bytes.<br />
"C:\Users\myles\AppData\Local\Arduino15\packages\m5stack\tools\esptool_py\4.5.1/esptool.exe" --chip esp32 --port "COM23" --baud 1500000  --before default_reset --after hard_reset write_flash  -z --flash_mode dio --flash_freq 80m --flash_size 16MB 0x1000 "C:\Users\myles\AppData\Local\Temp\arduino\sketches\90AA1942EA0BA4EF7597B8CEDA18AD54/nextgen.ino.bootloader.bin" 0x8000 "C:\Users\myles\AppData\Local\Temp\arduino\sketches\90AA1942EA0BA4EF7597B8CEDA18AD54/nextgen.ino.partitions.bin" 0xe000 "C:\Users\myles\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.1.1/tools/partitions/boot_app0.bin" 0x10000 "C:\Users\myles\AppData\Local\Temp\arduino\sketches\90AA1942EA0BA4EF7597B8CEDA18AD54/nextgen.ino.bin"<br />
<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v4.5.1<br />
Serial port COM23<br />
Connecting......................................</p>
<p dir="auto">A fatal error occurred: Failed to connect to ESP32: No serial data received.<br />
For troubleshooting steps visit: <a href="https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html</a><br />
Failed uploading: uploading error: exit status 2</p>
]]></description><link>https://community.m5stack.com/post/24438</link><guid isPermaLink="true">https://community.m5stack.com/post/24438</guid><dc:creator><![CDATA[mylesdebaerdemaeker]]></dc:creator><pubDate>Tue, 19 Mar 2024 14:28:00 GMT</pubDate></item><item><title><![CDATA[Reply to Fire is dead ... how can this be solved ? on Tue, 25 Apr 2023 07:19:21 GMT]]></title><description><![CDATA[<p dir="auto">try to use m5 burner, then erase or load new firmware thru it, i do have one core unit which suddenly stopped to display anything on lcd screen, i can connect to it, load projects but nothing is showing up on screen except backlight is on.</p>
]]></description><link>https://community.m5stack.com/post/20673</link><guid isPermaLink="true">https://community.m5stack.com/post/20673</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Tue, 25 Apr 2023 07:19:21 GMT</pubDate></item><item><title><![CDATA[Reply to Fire is dead ... how can this be solved ? on Mon, 24 Apr 2023 11:55:03 GMT]]></title><description><![CDATA[<p dir="auto">Have you tried using M5 Burner to erase and re write the firmware?</p>
]]></description><link>https://community.m5stack.com/post/20671</link><guid isPermaLink="true">https://community.m5stack.com/post/20671</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 24 Apr 2023 11:55:03 GMT</pubDate></item></channel></rss>
