<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t load program modifications...]]></title><description><![CDATA[<p dir="auto">I have a Core2-AWS and trying to learn how to use it.  I've done a lot of programming with Arduinos in the past...</p>
<p dir="auto">I had a program loaded into the M5Stack, and then went back to the M5Burner and loaded the UIFlow for the Core2 (top of the list).</p>
<p dir="auto">My M5Stack comes up as Com9 and I can load in my original "Hello World" that I wrote some months ago.  However, I can't see to do any mods to the program and get them to load (adding a box/label/sound, etc.).  The UIFlow just says that it's disconnected.<br />
I'm trying to figure out how I would go about writing and debugging a program, adding code, etc...  Keeps saying that it's "Disconnected".</p>
<p dir="auto">I tried via USB (local UIFlow exe) and TCPIP (Browser editor), but it always says that the device is disconnected.  Tried "Reset" and restarting...</p>
<p dir="auto">What am I doing wrong?</p>
<p dir="auto">Sir Michael</p>
]]></description><link>https://community.m5stack.com/topic/4875/can-t-load-program-modifications</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 20:25:44 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4875.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Dec 2022 20:05:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t load program modifications... on Sat, 17 Dec 2022 10:35:11 GMT]]></title><description><![CDATA[<p dir="auto">Slow response could be down to having the wrong baud speed set. UIFlow is built on Micropython and so does support multi files like arduino. Checkout Micropython. Org</p>
<p dir="auto">Esp is not like the arduino as instead of having functions permanently assigned to a pin, the esp using a matrix to assign functions to pins</p>
]]></description><link>https://community.m5stack.com/post/19581</link><guid isPermaLink="true">https://community.m5stack.com/post/19581</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 17 Dec 2022 10:35:11 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t load program modifications... on Fri, 16 Dec 2022 15:01:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a>,</p>
<p dir="auto">I haven’t gotten very far in learning the UIflow enough to learn if it supports the “tabs” like the Arduino ide.  I have some libraries that I often include in my sketches (i.e.: Morse code for error messaging) and it’s easier to put all of the buttons in one file, display in another, subroutines, etc….<br />
Does UIflow support anything like that?  Files?</p>
<p dir="auto">I’ll be honest, I don’t understand enough about the ESP32 to understand about your references to Expressif.   I have used an ESP32 for the Bluetooth as a solution to a problem that I had, but I am not using it at near its capacities.</p>
<p dir="auto">And to ajb2k3, I am in fact using the M5burner with the Core2 (as mentioned above).   It’s working, but just slow…. As a matter of fact, even the Arduino compiler is slow.<br />
I think that I may have some other interaction issues with some other install somewhere.</p>
]]></description><link>https://community.m5stack.com/post/19571</link><guid isPermaLink="true">https://community.m5stack.com/post/19571</guid><dc:creator><![CDATA[SirMichael]]></dc:creator><pubDate>Fri, 16 Dec 2022 15:01:10 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t load program modifications... on Mon, 12 Dec 2022 19:14:38 GMT]]></title><description><![CDATA[<p dir="auto">Have you tried Using M5Burner to erase the flash first before installing Core2 firmware?<br />
You MUST make sure to install Core2 and not Core firmware.</p>
]]></description><link>https://community.m5stack.com/post/19536</link><guid isPermaLink="true">https://community.m5stack.com/post/19536</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 12 Dec 2022 19:14:38 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t load program modifications... on Mon, 12 Dec 2022 17:32:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sirmichael" aria-label="Profile: sirmichael">@<bdi>sirmichael</bdi></a> If you HAVE experience with Arduino IDE and C, C++, then I agree that Arduino gives more control at a deeper level and IMHO worth the extra effort.<br />
Arduino for ESP32 however changed that, when  Espressif  took over the board config,  "updated" ESP_NOW such that older Arduino Sketches would no longer run, and  Arduino-as-slave was never implemented, both causing me hair-loss!<br />
Cheers!</p>
]]></description><link>https://community.m5stack.com/post/19533</link><guid isPermaLink="true">https://community.m5stack.com/post/19533</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Mon, 12 Dec 2022 17:32:12 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t load program modifications... on Mon, 12 Dec 2022 16:43:01 GMT]]></title><description><![CDATA[<p dir="auto">I gave up...  There were no answers and I couldn't get UIFlow to work.<br />
Went back to Arduino IDE.</p>
]]></description><link>https://community.m5stack.com/post/19530</link><guid isPermaLink="true">https://community.m5stack.com/post/19530</guid><dc:creator><![CDATA[SirMichael]]></dc:creator><pubDate>Mon, 12 Dec 2022 16:43:01 GMT</pubDate></item></channel></rss>
