<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unit cam DIY kit and Esphome]]></title><description><![CDATA[<p dir="auto">Hey, bought a unit cam DIY kit (<a href="https://shop.m5stack.com/products/unit-cam-wi-fi-camera-diy-kit-ov2640" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/unit-cam-wi-fi-camera-diy-kit-ov2640</a>)</p>
<p dir="auto">I hoped to get it working using Esphome within Home Assistant but no success so far. Anyone succeeded in adding the cam to Home assistant.<br />
I tried using platform Esp32 and board: m5stack-core-esp32 and using standard cam settings provided by esphome for m5stack.  After flashing the board starts generating psram errors</p>
<p dir="auto">Regards, Wim</p>
]]></description><link>https://community.m5stack.com/topic/4768/unit-cam-diy-kit-and-esphome</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 08:33:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4768.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 30 Oct 2022 19:56:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unit cam DIY kit and Esphome on Tue, 24 Dec 2024 17:04:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi Win,</p>
<p dir="auto">My is not working too.</p>
<p dir="auto">Pinout is the same as stated on <a href="https://docs.m5stack.com/en/unit/unit_cam" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/unit/unit_cam</a></p>
<p dir="auto">But in Homeassistant ESPHome generates these errors:</p>
<p dir="auto">[12:03:45][C][ledc.output:180]: LEDC Output:<br />
[12:03:45][C][ledc.output:181]:   Pin GPIO2<br />
[12:03:45][C][ledc.output:182]:   LEDC Channel: 2<br />
[12:03:45][C][ledc.output:183]:   PWM Frequency: 1000.0 Hz<br />
[12:03:45][C][ledc.output:184]:   Phase angle: 0.0°<br />
[12:03:45][C][ledc.output:185]:   Bit depth: 16<br />
[12:03:45][C][esp32_camera:048]: ESP32 Camera:<br />
[12:03:45][C][esp32_camera:049]:   Name: Timer-CAM1<br />
[12:03:45][C][esp32_camera:050]:   Internal: YES<br />
[12:03:45][C][esp32_camera:052]:   Data Pins: D0:32 D1:35 D2:34 D3:5 D4:39 D5:18 D6:36 D7:19<br />
[12:03:45][C][esp32_camera:053]:   VSYNC Pin: 22<br />
[12:03:45][C][esp32_camera:054]:   HREF Pin: 26<br />
[12:03:45][C][esp32_camera:055]:   Pixel Clock Pin: 21<br />
[12:03:45][C][esp32_camera:056]:   External Clock: Pin:27 Frequency:20000000<br />
[12:03:45][C][esp32_camera:060]:   I2C Pins: SDA:25 SCL:23<br />
[12:03:45][C][esp32_camera:062]:   Reset Pin: 15<br />
[12:03:45][C][esp32_camera:080]:   Resolution: 640x480 (VGA)<br />
[12:03:45][E][esp32_camera:123]:   Setup Failed: ESP_ERR_NOT_FOUND<br />
[12:03:45][E][component:082]:   Component esp32_camera is marked FAILED</p>
]]></description><link>https://community.m5stack.com/post/27568</link><guid isPermaLink="true">https://community.m5stack.com/post/27568</guid><dc:creator><![CDATA[SuperObob]]></dc:creator><pubDate>Tue, 24 Dec 2024 17:04:12 GMT</pubDate></item></channel></rss>
