<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StampC3]]></title><description><![CDATA[<p dir="auto">How is it possible to get UI flow on the M5StampC3. I have not managed it via the burner and not via Thony either. With Thony comes then always Invalid Header.</p>
]]></description><link>https://community.m5stack.com/topic/4439/m5stampc3</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 10:54:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4439.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Jul 2022 09:54:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StampC3 on Thu, 14 Jul 2022 11:40:27 GMT]]></title><description><![CDATA[<p dir="auto">For the Micropython version<br />
esp32c3-20220618-v1.19.1<br />
unfortunately the w-lan does not work properly.</p>
]]></description><link>https://community.m5stack.com/post/17997</link><guid isPermaLink="true">https://community.m5stack.com/post/17997</guid><dc:creator><![CDATA[Wolli01]]></dc:creator><pubDate>Thu, 14 Jul 2022 11:40:27 GMT</pubDate></item><item><title><![CDATA[Reply to M5StampC3 on Thu, 14 Jul 2022 07:17:36 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wolli01" aria-label="Profile: Wolli01">@<bdi>Wolli01</bdi></a></p>
<p dir="auto">yes, I think the UIFlow 2.0.2 firmware preview cannot yet be used with UIFlow.</p>
<p dir="auto">From the <a href="https://forum.m5stack.com/topic/3968/uiflow-2-0-0-firmware-preview-version" target="_blank" rel="noopener noreferrer nofollow ugc">2.0.0 announcement</a>:</p>
<p dir="auto"><em>It is now recommended that you help us develop and test firmware using:<br />
Thonny (highly recommended)<br />
Putty (command line)<br />
Pymakr (VS code plugin, from pycom)</em></p>
<p dir="auto">If you need UIFlow for your M5StampC3 I am afraid you'll need to wait until it has been implemented into the online version of UIFlow.</p>
]]></description><link>https://community.m5stack.com/post/17996</link><guid isPermaLink="true">https://community.m5stack.com/post/17996</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 14 Jul 2022 07:17:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5StampC3 on Thu, 14 Jul 2022 05:13:13 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the help, I got it working now.<br />
The downloader must be set uart instead of USB and the flash files must also be the ones without USB.<br />
Unfortunately, various things do not run, with UIFlow I get the message M5Stack Import * is not correct.</p>
]]></description><link>https://community.m5stack.com/post/17993</link><guid isPermaLink="true">https://community.m5stack.com/post/17993</guid><dc:creator><![CDATA[Wolli01]]></dc:creator><pubDate>Thu, 14 Jul 2022 05:13:13 GMT</pubDate></item><item><title><![CDATA[Reply to M5StampC3 on Wed, 13 Jul 2022 21:09:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wolli01" aria-label="Profile: Wolli01">@<bdi>Wolli01</bdi></a></p>
<p dir="auto">from your picture I take you are trying to flash an M5Stamp-C3<strong>U</strong>, is that correct? If yes, did you press button A while plugging USB in to force it into download mode?</p>
]]></description><link>https://community.m5stack.com/post/17991</link><guid isPermaLink="true">https://community.m5stack.com/post/17991</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 13 Jul 2022 21:09:28 GMT</pubDate></item><item><title><![CDATA[Reply to M5StampC3 on Wed, 13 Jul 2022 20:13:07 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1657743175026-ac16aee3-5513-4baf-a4be-f363d4148e79-grafik-resized.png" alt="0_1657743173470_ac16aee3-5513-4baf-a4be-f363d4148e79-grafik.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/17990</link><guid isPermaLink="true">https://community.m5stack.com/post/17990</guid><dc:creator><![CDATA[Wolli01]]></dc:creator><pubDate>Wed, 13 Jul 2022 20:13:07 GMT</pubDate></item><item><title><![CDATA[Reply to M5StampC3 on Wed, 13 Jul 2022 19:47:21 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wolli01" aria-label="Profile: Wolli01">@<bdi>Wolli01</bdi></a></p>
<p dir="auto">that sounds like you probably do not have the correct driver installed in your system yet.</p>
<p dir="auto">Also did you try to write the firmware at offset 0x0? (The C3 variant needs offset 0x0 instead of 0x1000.)</p>
]]></description><link>https://community.m5stack.com/post/17988</link><guid isPermaLink="true">https://community.m5stack.com/post/17988</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 13 Jul 2022 19:47:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5StampC3 on Wed, 13 Jul 2022 17:36:40 GMT]]></title><description><![CDATA[<p dir="auto">I've already tried that, but I couldn't get it to work. With the Flash Download Tool I do not come further, always stands Sync and paints only points hin over 30 min. long. Maybe I'm doing it wrong. About Thony I also do not get it done, there comes afterwards always Invalead header.</p>
]]></description><link>https://community.m5stack.com/post/17987</link><guid isPermaLink="true">https://community.m5stack.com/post/17987</guid><dc:creator><![CDATA[Wolli01]]></dc:creator><pubDate>Wed, 13 Jul 2022 17:36:40 GMT</pubDate></item><item><title><![CDATA[Reply to M5StampC3 on Wed, 13 Jul 2022 12:23:01 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wolli01" aria-label="Profile: Wolli01">@<bdi>Wolli01</bdi></a></p>
<p dir="auto">UIFlow 2.0.2 firmware preview version supposedly supports M5StampC3. See this <a href="https://community.m5stack.com/topic/4096/uiflow-2-0-2-firmware-preview-version">thread</a>.</p>
]]></description><link>https://community.m5stack.com/post/17984</link><guid isPermaLink="true">https://community.m5stack.com/post/17984</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 13 Jul 2022 12:23:01 GMT</pubDate></item><item><title><![CDATA[Reply to M5StampC3 on Wed, 13 Jul 2022 10:33:35 GMT]]></title><description><![CDATA[<p dir="auto">I don’t think there is a version available yet as the C3 uses RISC core not the normal cores found in esp32</p>
]]></description><link>https://community.m5stack.com/post/17983</link><guid isPermaLink="true">https://community.m5stack.com/post/17983</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 13 Jul 2022 10:33:35 GMT</pubDate></item></channel></rss>
