<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[GPIO16 as input not working?]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I am trying to use GPIO16 as input on an M5Stack Core, but it does not work.<br />
I tried using GPIO35 instead and that worked fine.</p>
<p dir="auto">But I want this signal on GPIO16. Any ideas on how to make that work?<br />
When searching for info on this I have not found any info that it shouldn't work. In general it says that it should work to use GPIO16 both as output and input.</p>
<p dir="auto">I am using GPIO17 as output and that is working fine.</p>
]]></description><link>https://community.m5stack.com/topic/3999/gpio16-as-input-not-working</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 22:15:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3999.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Feb 2022 17:16:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to GPIO16 as input not working? on Fri, 04 Feb 2022 05:09:52 GMT]]></title><description><![CDATA[<p dir="auto">GPIO is written in PinMap of M5Unified.</p>
<p dir="auto">M5Unified：PinMap<br />
<a href="https://github.com/m5stack/M5Unified" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Unified</a></p>
<p dir="auto"><img src="/assets/uploads/files/1643950446110-pinmap.png" alt="0_1643950391586_pinmap.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/16520</link><guid isPermaLink="true">https://community.m5stack.com/post/16520</guid><dc:creator><![CDATA[macsbug]]></dc:creator><pubDate>Fri, 04 Feb 2022 05:09:52 GMT</pubDate></item><item><title><![CDATA[Reply to GPIO16 as input not working? on Fri, 04 Feb 2022 05:03:14 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/thomasx" aria-label="Profile: Thomasx">@<bdi>Thomasx</bdi></a></p>
<p dir="auto">judging from your other posts I assume you mean M5Core2 (the one with touch interface). If so on M5Core2 GPIO16 and GPIO17 are used internally for PSRAM - they cannot be used for anything else.</p>
<p dir="auto">Note: if for whatever reason you really need GPIO16 as output you'd need to switch to an M5Stack (Basic, Go or Gray). Not M5Stack Fire as it also has PSRAM.</p>
]]></description><link>https://community.m5stack.com/post/16518</link><guid isPermaLink="true">https://community.m5stack.com/post/16518</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 04 Feb 2022 05:03:14 GMT</pubDate></item></channel></rss>
