<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header]]></title><description><![CDATA[<p dir="auto">Help!</p>
<p dir="auto">When I try uploading a sketch using Windows 10, and Arduino 1.8.15 to my Core2 I get the following:</p>
<p dir="auto">"Connecting.......<strong><strong>.......</strong></strong>.......<strong><strong>.......</strong></strong>.......____<br />
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header"</p>
<p dir="auto">If I just select the "Serial Monitor" while the Core2's plugged in - when I reboot the Core 2, the Serial Monitor shows the bootup text, so the device is definitely connected AND communicating through all the USB ports I tried.</p>
<p dir="auto">The Core Grey I bought earlier is working fine... it flashes every time without issue.</p>
<p dir="auto">I've tried the following:</p>
<li>I've used both USB cables that came with my Core Grey and Core2, and a 3rd party cable. (all three work with my Core Grey)</li>
<li>I've slowed down/turned off the LIFO stacks in Device Manager for COM4 - where the device appears.</li>
<li>I've slowed down the connection via Device Manager. (same windows as #2)</li>
<li>Uninstalled Arduino software, then reinstalled.</li>
<li>Used Device Manager to uninstall the serial drivers (ticked "From disk" too), then reinstalled by reinstalling the Arduino software.</li>
<li>Googled online..... only found this for a bare ESP32 board: <a href="https://randomnerdtutorials.com/solved-failed-to-connect-to-esp32-timed-out-waiting-for-packet-header/" target="_blank" rel="noopener noreferrer nofollow ugc">https://randomnerdtutorials.com/solved-failed-to-connect-to-esp32-timed-out-waiting-for-packet-header/</a></li>
<li>Tried the USB 3 laptop socket (blue plastic).</li>
<li>Tried the USB 2 laptop socket.</li>
<li>Powered off the laptop and powered back on.</li>
<li>Removed the Core2 battery, and tried flashing again.</li>
<li>Tried using the esptool.exe 3.0-dev version on the command line in a temporary batch file. (same message)<br />
Command: "esptool.exe --chip esp32 --port COM8 --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 C:....esp32\1.0.6/tools/partitions/boot_app0.bin 0x1000 C:....esp32\hardware\esp32\1.0.6/tools/sdk/bin/bootloader_dio_80m.bin 0x10000 C:....\arduino_build_567398/circles.ino.bin 0x8000 C:....\Temp\arduino_build_567398/circles.ino.partitions.bin"</li>
<li>Tried tapping the Reset button while "Connecting..." is being displayed.</li>
<li>Arduino settings: Ensured the board is "M5Stack-Core2"</li>
<li>Arduino settings: Tried 115200 for the upload speed.</li>
<li>Tried a hub plugged into the laptop.</li>
<li>Tried an externally powered USB 3 hub.</li>
<p dir="auto">I've ran out of things to try!</p>
<p dir="auto">Do I need a new Core2? How do I go about it? I don't want my money back - I love the touchscreen!</p>
]]></description><link>https://community.m5stack.com/topic/3504/a-fatal-error-occurred-failed-to-connect-to-esp32-timed-out-waiting-for-packet-header</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 09:46:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3504.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Aug 2021 19:35:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header on Tue, 10 Jun 2025 16:26:48 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/hacxx" aria-label="Profile: hacxx">@<bdi>hacxx</bdi></a></p>
<p dir="auto">please refrain from posting in year old threads which are already resolved. Thank you.</p>
]]></description><link>https://community.m5stack.com/post/29213</link><guid isPermaLink="true">https://community.m5stack.com/post/29213</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 10 Jun 2025 16:26:48 GMT</pubDate></item><item><title><![CDATA[Reply to A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header on Tue, 10 Jun 2025 07:48:28 GMT]]></title><description><![CDATA[<p dir="auto">You're clearly doing everything right—this is a common ESP32 upload issue. Since the Core2 boots and shows output in Serial Monitor, the USB connection works, but upload mode isn't triggering.</p>
<p dir="auto">Here’s what to try (if you haven’t already):</p>
<pre><code>1. Hold Boot Button (if available): While uploading, hold the reset/boot button until upload starts. Some Core2s need manual bootloader mode.
2. Try 115200 Baud: You've tried this—stick with it; higher speeds can fail on some USB ports.
3. Check CP210x or CH340 Driver: Reinstall the correct USB-to-serial driver for the Core2.
<p dir="auto">If none of that helps, your Core2’s USB-UART chip might be defective. Exchange it through M5Stack support.</p>
]]></description><link>https://community.m5stack.com/post/29211</link><guid isPermaLink="true">https://community.m5stack.com/post/29211</guid><dc:creator><![CDATA[hacxx]]></dc:creator><pubDate>Tue, 10 Jun 2025 07:48:28 GMT</pubDate></item><item><title><![CDATA[Reply to A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header on Tue, 10 Aug 2021 15:34:34 GMT]]></title><description><![CDATA[<p dir="auto">It turned out to be my Ryzen Swift 3 USB drivers!</p>
<p dir="auto">After updating them the problem resolved.</p>
]]></description><link>https://community.m5stack.com/post/14613</link><guid isPermaLink="true">https://community.m5stack.com/post/14613</guid><dc:creator><![CDATA[SarahC]]></dc:creator><pubDate>Tue, 10 Aug 2021 15:34:34 GMT</pubDate></item></channel></rss>
