<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core 2 with Sim 800 module.]]></title><description><![CDATA[<p dir="auto">Is the M5Stack SIM800 module compatible with the Core 2?</p>
<p dir="auto">I just connected and I have noticed the Red Port A has stopped working.<br />
Any advice appreciated, thank you.</p>
]]></description><link>https://community.m5stack.com/topic/3044/core-2-with-sim-800-module</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Mar 2026 23:37:37 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3044.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Mar 2021 22:41:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core 2 with Sim 800 module. on Thu, 13 Jan 2022 18:56:44 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/11670">@BrandPlay</a></p>
<p dir="auto">does your M5Core2 turn on ok w/o the SIM800L stacked to it?</p>
<p dir="auto">If you are using the M5Core2 battery, it is fully charged?</p>
<p dir="auto">If you power your M5Core2 from USB, have you tried a different cable / power source?</p>
]]></description><link>https://community.m5stack.com/post/16176</link><guid isPermaLink="true">https://community.m5stack.com/post/16176</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 13 Jan 2022 18:56:44 GMT</pubDate></item><item><title><![CDATA[Reply to Core 2 with Sim 800 module. on Thu, 13 Jan 2022 17:48:53 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a>. I have a problem with connecting SIM800L(M004) with Core 2 . When I try to turn Core on it just light build in LED for second and turn it off. Core did not start, but when i give 5v from another power supply to SIM800L it starts properly. Did you have problem like that?</p>
]]></description><link>https://community.m5stack.com/post/16175</link><guid isPermaLink="true">https://community.m5stack.com/post/16175</guid><dc:creator><![CDATA[BrandPlay]]></dc:creator><pubDate>Thu, 13 Jan 2022 17:48:53 GMT</pubDate></item><item><title><![CDATA[Reply to Core 2 with Sim 800 module. on Wed, 10 Mar 2021 20:04:30 GMT]]></title><description><![CDATA[<p dir="auto">Hello guys</p>
<p dir="auto">I just got a GSM SIM800L module and have it working with M5Core2 by changing RX2 from GPIO16 to GPIO13 and TX2 from GPIO17 to GPIO14.</p>
<p dir="auto">What I stated before about GPIO5 being used for RST turned out to be only half the truth. Sorry about that. By default RST is unconnected, but a solder bridge can be made to connect RST to GPIO5 in case the application needs to reset the module.</p>
]]></description><link>https://community.m5stack.com/post/12919</link><guid isPermaLink="true">https://community.m5stack.com/post/12919</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 10 Mar 2021 20:04:30 GMT</pubDate></item><item><title><![CDATA[Reply to Core 2 with Sim 800 module. on Fri, 05 Mar 2021 14:29:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4560">@ksprayberry</a><br />
I agree with you. I bought a Fire and a Core2 with two Lora modules, in the Fire it fits perfectly and in the Core2 it does not. Now it will force me to buy another Fire if I want to use another type of module. I have not been able to use them.</p>
<p dir="auto">I don't think it's a good policy, in the same brand, not to make everything compatible. This is my personal opinion</p>
<p dir="auto">Regards<br />
Carles</p>
]]></description><link>https://community.m5stack.com/post/12832</link><guid isPermaLink="true">https://community.m5stack.com/post/12832</guid><dc:creator><![CDATA[Carles B.]]></dc:creator><pubDate>Fri, 05 Mar 2021 14:29:31 GMT</pubDate></item><item><title><![CDATA[Reply to Core 2 with Sim 800 module. on Fri, 05 Mar 2021 12:26:22 GMT]]></title><description><![CDATA[<p dir="auto">This seems to be pretty common. Not all modules are compatible with all cores. I wish they would advertise which modules work with which cores.</p>
]]></description><link>https://community.m5stack.com/post/12827</link><guid isPermaLink="true">https://community.m5stack.com/post/12827</guid><dc:creator><![CDATA[ksprayberry]]></dc:creator><pubDate>Fri, 05 Mar 2021 12:26:22 GMT</pubDate></item><item><title><![CDATA[Reply to Core 2 with Sim 800 module. on Fri, 05 Mar 2021 08:51:21 GMT]]></title><description><![CDATA[<p dir="auto">Thank you!</p>
]]></description><link>https://community.m5stack.com/post/12824</link><guid isPermaLink="true">https://community.m5stack.com/post/12824</guid><dc:creator><![CDATA[pipy71]]></dc:creator><pubDate>Fri, 05 Mar 2021 08:51:21 GMT</pubDate></item><item><title><![CDATA[Reply to Core 2 with Sim 800 module. on Fri, 05 Mar 2021 06:58:05 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3911">@pipy71</a></p>
<p dir="auto">looking at the GSM SIM800L pin map or schematic I can see that GPIO5 is used as reset (RST). On M5Core2 GPIO5 was replaced with GPIO33 which is also used for SCL (I2C) on M5Core2 Red Port A. That is why it stopped working.</p>
<p dir="auto">In other words the GSM SIM800L module is not fully compatible with M5Core2. It can only be used if you disable the external I2C on the Red Port A.</p>
<p dir="auto">I've made a comparison list of all the GPIO changes between M5Stack and M5Core2. You can find it <a href="https://www.gwendesign.ch/kb/m5stack/m5core2/#m5core2-bus-and-gpios-compared-to-m5stack" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/12821</link><guid isPermaLink="true">https://community.m5stack.com/post/12821</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 05 Mar 2021 06:58:05 GMT</pubDate></item></channel></rss>
