<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Separate firmware from M5burner]]></title><description><![CDATA[<p dir="auto">Would it be possible to get the firmware from M5Burner as to make possible for those of us that can not run m5burner on our machines?</p>
<p dir="auto">That way we could load them with esptool or similar.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/3002/separate-firmware-from-m5burner</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 02:37:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3002.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 25 Feb 2021 01:18:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Separate firmware from M5burner on Sun, 14 Mar 2021 15:31:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7475">@scottknight</a> Hey hi,<br />
I just changed my chromebook to an Intel based one. But the ARM one did not even run M5Burner.</p>
<p dir="auto">So yes... if your CHromebook is Intel processor based, you can run m5burner.</p>
<p dir="auto">Thanks for the listing of directories for using the firmware directly with esptool</p>
]]></description><link>https://community.m5stack.com/post/13007</link><guid isPermaLink="true">https://community.m5stack.com/post/13007</guid><dc:creator><![CDATA[BricoMS]]></dc:creator><pubDate>Sun, 14 Mar 2021 15:31:56 GMT</pubDate></item><item><title><![CDATA[Reply to Separate firmware from M5burner on Sun, 14 Mar 2021 12:40:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/6705">@bricoms</a> said in <a href="/post/12751">Separate firmware from M5burner</a>:</p>
<p dir="auto">Thanks Lukas!<br />
Yes what i did is i used my wife Windows machine to install M5Burner and i downloded all the firmwares for all devices then went to the directory and copied them to an  sd card to have on my Chromebook.</p>
<p dir="auto">I did something very similar.  The M5Burner program had no problem downloading the firmware when running from the Crostini shell on the Chromebook, but threw a weird error while trying to flash the firmware on every device I own.  After fiddling around with it way too long, I finally gave up and just flashed the firmware using the esptool.  They get downloaded into a pretty handy directory structure from whereever you run the M5Flasher from.  Here are a few from my projects:<br />
./M5Burner/packages/fw/core/SonicTheHedgehog-v1.0.bin<br />
./M5Burner/packages/fw/core/UIFlow_Fire-v1.7.2-fire.bin<br />
./M5Burner/packages/fw/stickc/UIFlow_StickC_Plus-v1.7.2-plus.bin<br />
./M5Burner/packages/fw/atom/UIFlow_Lite-v1.7.2.bin<br />
./M5Burner/packages/fw/atom/UIFlow_Lite-v1.7.2.bin</p>
]]></description><link>https://community.m5stack.com/post/13004</link><guid isPermaLink="true">https://community.m5stack.com/post/13004</guid><dc:creator><![CDATA[ScottKnight]]></dc:creator><pubDate>Sun, 14 Mar 2021 12:40:34 GMT</pubDate></item><item><title><![CDATA[Reply to Separate firmware from M5burner on Thu, 04 Mar 2021 13:42:07 GMT]]></title><description><![CDATA[<p dir="auto">M5Burner and UiFlow desktop only run on 64bit version of Windows 10.</p>
]]></description><link>https://community.m5stack.com/post/12805</link><guid isPermaLink="true">https://community.m5stack.com/post/12805</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Thu, 04 Mar 2021 13:42:07 GMT</pubDate></item><item><title><![CDATA[Reply to Separate firmware from M5burner on Thu, 04 Mar 2021 06:27:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/6972">@jimwsmith</a> said in <a href="/post/12759">Separate firmware from M5burner</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/187">@world101</a> It doesn't run on one of our students Windows 10 32bit machine</p>
<p dir="auto">Does it generate an error message to say why it doesn't run?<br />
There are many many reasons why it could fail.</p>
]]></description><link>https://community.m5stack.com/post/12793</link><guid isPermaLink="true">https://community.m5stack.com/post/12793</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 04 Mar 2021 06:27:48 GMT</pubDate></item><item><title><![CDATA[Reply to Separate firmware from M5burner on Tue, 02 Mar 2021 18:27:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/187">@world101</a> It doesn't run on one of our students Windows 10 32bit machine</p>
]]></description><link>https://community.m5stack.com/post/12759</link><guid isPermaLink="true">https://community.m5stack.com/post/12759</guid><dc:creator><![CDATA[jimwsmith]]></dc:creator><pubDate>Tue, 02 Mar 2021 18:27:50 GMT</pubDate></item><item><title><![CDATA[Reply to Separate firmware from M5burner on Tue, 02 Mar 2021 14:08:55 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Lukas!<br />
]]></description><link>https://community.m5stack.com/post/12751</link><guid isPermaLink="true">https://community.m5stack.com/post/12751</guid><dc:creator><![CDATA[BricoMS]]></dc:creator><pubDate>Tue, 02 Mar 2021 14:08:55 GMT</pubDate></item><item><title><![CDATA[Reply to Separate firmware from M5burner on Sat, 27 Feb 2021 02:33:30 GMT]]></title><description><![CDATA[<p dir="auto">If your on mac the downloaded firmwares can be found by right clicking M5Burner selecting "Show Package contents" then clicking through to Contents &gt; Resources &gt; Packages &gt; fw then you will find the firmware files in each respective core folders. I don't have a linux machine handy at the moment but perhaps the folder structure is similar</p>
]]></description><link>https://community.m5stack.com/post/12691</link><guid isPermaLink="true">https://community.m5stack.com/post/12691</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Sat, 27 Feb 2021 02:33:30 GMT</pubDate></item><item><title><![CDATA[Reply to Separate firmware from M5burner on Thu, 25 Feb 2021 02:57:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/187">@world101</a> hi!</p>
<p dir="auto">Well linux is a wide word. I am on chromebook, it does have linux, but it is arm architecture. Also wont run on raspberry as far as i know. Pops out a lot of errors, i tried installing as much support libraries as i could.</p>
]]></description><link>https://community.m5stack.com/post/12662</link><guid isPermaLink="true">https://community.m5stack.com/post/12662</guid><dc:creator><![CDATA[BricoMS]]></dc:creator><pubDate>Thu, 25 Feb 2021 02:57:20 GMT</pubDate></item><item><title><![CDATA[Reply to Separate firmware from M5burner on Thu, 25 Feb 2021 02:33:53 GMT]]></title><description><![CDATA[<p dir="auto">What machine can you not run M5Burner on? It’s supported on Windows,  Mac, and Linux. Curious what else you might be using.</p>
<p dir="auto">Anyway, you should be able to download M5Burner and extract the firmware from it, at least for Mac or Linux. Not sure about Windows... I’m a Mac guy.</p>
]]></description><link>https://community.m5stack.com/post/12660</link><guid isPermaLink="true">https://community.m5stack.com/post/12660</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Thu, 25 Feb 2021 02:33:53 GMT</pubDate></item></channel></rss>
