<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m5stack fire black screen after i conected servo motor to it]]></title><description><![CDATA[<p dir="auto"><strong>Hi everyone</strong> , so my m5stack fire suddenly become black screen after I connected servo motor to it .</p>
<p dir="auto">this happened before  like month ago so I tried to update the firmware and it worked and back to normal but this time when I connect it to my laptop and update the firmware it doesn't work and fail.</p>
<p dir="auto">btw it only make some sounds and the red led lights but the screen is black.</p>
<p dir="auto">also can I know why when I connect it to servo motor this happens?</p>
<p dir="auto"><strong>thanks</strong></p>
]]></description><link>https://community.m5stack.com/topic/2959/m5stack-fire-black-screen-after-i-conected-servo-motor-to-it</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 21:02:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2959.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Feb 2021 12:18:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m5stack fire black screen after i conected servo motor to it on Fri, 26 Feb 2021 14:59:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a>  , <a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> sorry but any ideas?</p>
]]></description><link>https://community.m5stack.com/post/12682</link><guid isPermaLink="true">https://community.m5stack.com/post/12682</guid><dc:creator><![CDATA[abdullrhman]]></dc:creator><pubDate>Fri, 26 Feb 2021 14:59:36 GMT</pubDate></item><item><title><![CDATA[Reply to m5stack fire black screen after i conected servo motor to it on Sat, 20 Feb 2021 23:46:09 GMT]]></title><description><![CDATA[<p dir="auto">I have a similar problem. I powerd my M5Stack core black from a Stepmotor module and was not able to connect with the WLAN for programming. So I connected a small powerbank to the USB-C of the M5Stack. After resetting the display stayed black. Using a power adapter for the USB-C port also did not change anything. The M5Stack did not start. What I found out was that the powerbank did not deliver 5V correctly ( I measured 3.7V). May there be a conflict with the charging circuit when the Core is powerd over the Stepmotormodule (12V) and a voltage lower than 5V from the USB-Cat the same time?<br />
Some weeks ago my M5Stack grey stopped working when i tested a LEGO+ module.<br />
Now I have a black and a grey module and both displays keep dark and are not working.<br />
Any ideas?</p>
]]></description><link>https://community.m5stack.com/post/12584</link><guid isPermaLink="true">https://community.m5stack.com/post/12584</guid><dc:creator><![CDATA[dermax]]></dc:creator><pubDate>Sat, 20 Feb 2021 23:46:09 GMT</pubDate></item></channel></rss>
