<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Paper Speaker]]></title><description><![CDATA[<p dir="auto">Hello all,<br />
quick question, it seems the M5Paper does not have a speaker. Would it be possible to add one?</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://community.m5stack.com/topic/2704/m5paper-speaker</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 11:15:51 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2704.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Jan 2021 21:35:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Paper Speaker on Wed, 13 Jan 2021 05:44:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/187">@world101</a> Thanks for your reply. For the project I have in mind, I just only need beeps, but if I'm going to hack around, I'll try to attach a speaker since it would allow me to do many other things. For programming I'd go with Arduino.</p>
]]></description><link>https://community.m5stack.com/post/11699</link><guid isPermaLink="true">https://community.m5stack.com/post/11699</guid><dc:creator><![CDATA[kaderno]]></dc:creator><pubDate>Wed, 13 Jan 2021 05:44:38 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper Speaker on Wed, 13 Jan 2021 05:42:07 GMT]]></title><description><![CDATA[<p dir="auto">@mati I've posted the suggestion on the wish list but somehow it got deleted :S</p>
]]></description><link>https://community.m5stack.com/post/11698</link><guid isPermaLink="true">https://community.m5stack.com/post/11698</guid><dc:creator><![CDATA[kaderno]]></dc:creator><pubDate>Wed, 13 Jan 2021 05:42:07 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper Speaker on Mon, 11 Jan 2021 13:15:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/2327">@veryalien</a></p>
<p dir="auto">Thanks for your updates. I will give it a try.</p>
]]></description><link>https://community.m5stack.com/post/11649</link><guid isPermaLink="true">https://community.m5stack.com/post/11649</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Mon, 11 Jan 2021 13:15:41 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper Speaker on Sun, 10 Jan 2021 12:37:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/187">@world101</a> You can just use the files in the ESP32-A2DP project as a start.<br />
I didn't change anything in the arduino library, I just had to change the name of the speaker (obviously) in the bt_music_sender_write example. There's an error in that sample project at the moment as StarWars10 is defined, but the data is actually called StarWars30, just rename it and it should compile.<br />
I had the problem that the original sample played at double speed! I've followed the instructions to create new samples in audacity and export/convert them. Make sure to exactly create 44100 <strong>stereo</strong> 16-bit PCM data files, convert with xxd and then use TwoChannelSoundData so it plays at the correct speed.</p>
]]></description><link>https://community.m5stack.com/post/11638</link><guid isPermaLink="true">https://community.m5stack.com/post/11638</guid><dc:creator><![CDATA[veryalien]]></dc:creator><pubDate>Sun, 10 Jan 2021 12:37:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper Speaker on Sun, 10 Jan 2021 12:29:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/2327">@veryalien</a><br />
That’s awesome! Care to share your project and samples? I would like to play around with it.</p>
]]></description><link>https://community.m5stack.com/post/11637</link><guid isPermaLink="true">https://community.m5stack.com/post/11637</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sun, 10 Jan 2021 12:29:24 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper Speaker on Sun, 10 Jan 2021 11:44:21 GMT]]></title><description><![CDATA[<p dir="auto">Have you got a bluetooth speaker?</p>
<p dir="auto">If so, you could try using your M5Paper to send audio using a bluetooth a2dp connection to your speaker.</p>
<p dir="auto">I found this arduino project:</p>
<p dir="auto"><a href="https://github.com/pschatzmann/ESP32-A2DP" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/pschatzmann/ESP32-A2DP</a></p>
<p dir="auto">After making my own audio sample files, I can send audio from my M5Paper to my M5 Atom Echo (running the default factory firmware). I can also send to my other Urban Revolt bluetooth speaker, so it seems to be working correctly.</p>
]]></description><link>https://community.m5stack.com/post/11635</link><guid isPermaLink="true">https://community.m5stack.com/post/11635</guid><dc:creator><![CDATA[veryalien]]></dc:creator><pubDate>Sun, 10 Jan 2021 11:44:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper Speaker on Fri, 08 Jan 2021 19:10:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/187">@world101</a> yep also this is a bit strange we have SPK Hat for Stick but there is no standalone SPK. I think all core units got own internal SPK.</p>
]]></description><link>https://community.m5stack.com/post/11621</link><guid isPermaLink="true">https://community.m5stack.com/post/11621</guid><dc:creator><![CDATA[OyczE]]></dc:creator><pubDate>Fri, 08 Jan 2021 19:10:44 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper Speaker on Fri, 08 Jan 2021 12:25:57 GMT]]></title><description><![CDATA[<p dir="auto">I guess it depends on what you want to do. I assume you want an external speaker, correct? If so, what are your requirements (just buzzer beeps/tones or full wav/mp3 audio) and how do you want to program it (Arduino, uiFlow, or MicroPython)? There are plenty of options out there if you search for I2C speaker.</p>
]]></description><link>https://community.m5stack.com/post/11610</link><guid isPermaLink="true">https://community.m5stack.com/post/11610</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Fri, 08 Jan 2021 12:25:57 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper Speaker on Thu, 07 Jan 2021 21:04:02 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your reply. I'll put the question within the wish list topics although if anyone could lead me on how to do it myself, it would be great too :)</p>
]]></description><link>https://community.m5stack.com/post/11592</link><guid isPermaLink="true">https://community.m5stack.com/post/11592</guid><dc:creator><![CDATA[kaderno]]></dc:creator><pubDate>Thu, 07 Jan 2021 21:04:02 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper Speaker on Thu, 07 Jan 2021 16:04:16 GMT]]></title><description><![CDATA[<p dir="auto">post this here<br />
<a href="https://forum.m5stack.com/category/40/features-wish-list" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.m5stack.com/category/40/features-wish-list</a></p>
]]></description><link>https://community.m5stack.com/post/11584</link><guid isPermaLink="true">https://community.m5stack.com/post/11584</guid><dc:creator><![CDATA[OyczE]]></dc:creator><pubDate>Thu, 07 Jan 2021 16:04:16 GMT</pubDate></item></channel></rss>
