<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CoreInk deepsleep]]></title><description><![CDATA[<p dir="auto">How to deepsleep a CoreInk. The shutdown() gives a compiler error. Any idea?</p>
]]></description><link>https://community.m5stack.com/topic/2526/coreink-deepsleep</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 10:17:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2526.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Nov 2020 11:06:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CoreInk deepsleep on Mon, 30 Nov 2020 10:59:45 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1445">@ckuehnel</a></p>
<p dir="auto">Without opening M5CoreInk you probably cannot measure battery voltage with a multimeter. However you can use GPIO35 to read the battery voltage. Check out <code>float getBatVoltage()</code> <a href="https://github.com/m5stack/M5-CoreInk/blob/master/examples/FactoryTest/FactoryTest.ino" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">BTW: I've opened my M5CoreInk today and added some photos to my page (link below). Measuring power consumption in light sleep, deep sleep and shutdown will be next.</p>
<p dir="auto">Cheers<br />
]]></description><link>https://community.m5stack.com/post/10944</link><guid isPermaLink="true">https://community.m5stack.com/post/10944</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 30 Nov 2020 10:59:45 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk deepsleep on Mon, 30 Nov 2020 00:19:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> It seems to me that I measure not the battery voltage. The voltage is always around 4.8 V and this could be the voltage after the SY7088. So I can use that voltage as an indicator for enough battery voltage only. If I have schematics then I have the chance to a little bit deeper. Until now I did not find the schematics, yet.<br />
Ciao Claus</p>
]]></description><link>https://community.m5stack.com/post/10935</link><guid isPermaLink="true">https://community.m5stack.com/post/10935</guid><dc:creator><![CDATA[ckuehnel]]></dc:creator><pubDate>Mon, 30 Nov 2020 00:19:50 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk deepsleep on Sun, 29 Nov 2020 15:53:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1445">@ckuehnel</a></p>
<p dir="auto">great, I am glad you've figured it out. I am looking forward to hearing what you find regarding internal battery voltage over time.</p>
]]></description><link>https://community.m5stack.com/post/10932</link><guid isPermaLink="true">https://community.m5stack.com/post/10932</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 29 Nov 2020 15:53:10 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk deepsleep on Sun, 29 Nov 2020 15:38:36 GMT]]></title><description><![CDATA[<p dir="auto">After looking into Github I must see that the installed library differed from the library at Github now.<br />
After updating the compilation worked and I can test the internal battery voltage over time.</p>
]]></description><link>https://community.m5stack.com/post/10931</link><guid isPermaLink="true">https://community.m5stack.com/post/10931</guid><dc:creator><![CDATA[ckuehnel]]></dc:creator><pubDate>Sun, 29 Nov 2020 15:38:36 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk deepsleep on Sun, 29 Nov 2020 12:28:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> I tried the same w/o success. I will go into Github to look for.</p>
]]></description><link>https://community.m5stack.com/post/10925</link><guid isPermaLink="true">https://community.m5stack.com/post/10925</guid><dc:creator><![CDATA[ckuehnel]]></dc:creator><pubDate>Sun, 29 Nov 2020 12:28:45 GMT</pubDate></item><item><title><![CDATA[Reply to CoreInk deepsleep on Sun, 29 Nov 2020 12:13:55 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1445">@ckuehnel</a></p>
<p dir="auto">I am running this <a href="https://github.com/m5stack/M5-CoreInk/blob/master/examples/RTC_WakeUp/RTC_WakeUp.ino" target="_blank" rel="noopener noreferrer nofollow ugc">example</a> from master branch successfully on my CoreInk. Care to share your code?</p>
]]></description><link>https://community.m5stack.com/post/10924</link><guid isPermaLink="true">https://community.m5stack.com/post/10924</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 29 Nov 2020 12:13:55 GMT</pubDate></item></channel></rss>
