<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ENV II Unit Support for UI Flow (device M5StickC)]]></title><description><![CDATA[<p dir="auto">Hello guys, I purchased 3 pieces of ENV II Unit for my M5StickCs, but this does not work on my side. I see in UI Flow that ENV II is not available.</p>
<p dir="auto">Is there some example for ENV II and UI Flow/M5StickC?</p>
<p dir="auto">Thanks for advice.</p>
<p dir="auto">Cheers,<br />
Martin</p>
]]></description><link>https://community.m5stack.com/topic/2013/env-ii-unit-support-for-ui-flow-device-m5stickc</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 08:55:17 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2013.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Jun 2020 10:19:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ENV II Unit Support for UI Flow (device M5StickC) on Tue, 09 Mar 2021 06:59:10 GMT]]></title><description><![CDATA[<p dir="auto">Under the picture of the StickC in UIFLow is Unit/HAT and a + sign.<br />
Click on HAT then click + and select ENVII to add the EnvII to the workflow.<br />
UIflow then automatically imports the needed libraries required to use it so all you need to do is add the blocks that appear in HAT&gt;ENVII menu.</p>
]]></description><link>https://community.m5stack.com/post/12898</link><guid isPermaLink="true">https://community.m5stack.com/post/12898</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 09 Mar 2021 06:59:10 GMT</pubDate></item><item><title><![CDATA[Reply to ENV II Unit Support for UI Flow (device M5StickC) on Mon, 08 Mar 2021 07:47:53 GMT]]></title><description><![CDATA[<p dir="auto">I’m sorry to post once more, but there sa something I did not get.<br />
In fact, my mistake was to use th Demo button in UIFlow.<br />
There is only a demo for Env v1 and this is what I modified.<br />
The link in the documentation was for a proper ENV v2 UIFlow program but as I never used m5f and there was no prior information in the documentation, I thought it was the same as the Demo in UIFlow.</p>
<p dir="auto">I know I must pay more attention, but if a beginner comes to the documentation, I think there must be a link to usage of m5f files before.</p>
<p dir="auto">That’s it, sorry for the noise 🤷‍♂️😇</p>
]]></description><link>https://community.m5stack.com/post/12875</link><guid isPermaLink="true">https://community.m5stack.com/post/12875</guid><dc:creator><![CDATA[TitiMoby]]></dc:creator><pubDate>Mon, 08 Mar 2021 07:47:53 GMT</pubDate></item><item><title><![CDATA[Reply to ENV II Unit Support for UI Flow (device M5StickC) on Sun, 07 Mar 2021 17:47:57 GMT]]></title><description><![CDATA[<p dir="auto">And the answer was to learn how to handle Hat with UIFlow 🤣<br />
If someone tries to use ENV 2 demo, beware that it references the ENV hat version one.<br />
You need to remove it, add the ENV 2 hat, the replace with the new module functions the different calls.</p>
<p dir="auto">If someone knows how to do it, I can report the documentation error.</p>
]]></description><link>https://community.m5stack.com/post/12867</link><guid isPermaLink="true">https://community.m5stack.com/post/12867</guid><dc:creator><![CDATA[TitiMoby]]></dc:creator><pubDate>Sun, 07 Mar 2021 17:47:57 GMT</pubDate></item><item><title><![CDATA[Reply to ENV II Unit Support for UI Flow (device M5StickC) on Sun, 07 Mar 2021 17:36:04 GMT]]></title><description><![CDATA[<p dir="auto">I just spotted your topic and I'm wondering how you solved the issue.<br />
I'm running the current 1.7.2 UIFlow and firmware but when opening ENV II demo from the <a href="https://docs.m5stack.com/#/en/hat/hat_envII?id=example" target="_blank" rel="noopener noreferrer nofollow ugc">documentation page</a> it does not recognize the ENV II Hat and error message appear about not connected hat.</p>
<p dir="auto">As I also use micropython, I inspected modules and saw that there was a hat.ENV2.<br />
So I just had to modify one line of code.</p>
<p dir="auto">But I did not figure out how to do it from UIFLow blocks.<br />
What is the solution?</p>
]]></description><link>https://community.m5stack.com/post/12865</link><guid isPermaLink="true">https://community.m5stack.com/post/12865</guid><dc:creator><![CDATA[TitiMoby]]></dc:creator><pubDate>Sun, 07 Mar 2021 17:36:04 GMT</pubDate></item><item><title><![CDATA[Reply to ENV II Unit Support for UI Flow (device M5StickC) on Thu, 04 Jun 2020 11:06:41 GMT]]></title><description><![CDATA[<p dir="auto">Definitely solved by update firmware to 1.5.3 :-) Works perfectly, thanks for nice job.</p>
]]></description><link>https://community.m5stack.com/post/8902</link><guid isPermaLink="true">https://community.m5stack.com/post/8902</guid><dc:creator><![CDATA[martinpaulik]]></dc:creator><pubDate>Thu, 04 Jun 2020 11:06:41 GMT</pubDate></item></channel></rss>
