<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to use DS18B20 or NTC10k in Uiflow?]]></title><description><![CDATA[<p dir="auto">How to use DS18B20 or NTC10k in Uiflow?</p>
]]></description><link>https://community.m5stack.com/topic/1769/how-to-use-ds18b20-or-ntc10k-in-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 08:41:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1769.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Mar 2020 10:28:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to use DS18B20 or NTC10k in Uiflow? on Wed, 29 Jan 2025 08:14:45 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/stonatm/UiFlow-custom-blocks" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/stonatm/UiFlow-custom-blocks</a></p>
]]></description><link>https://community.m5stack.com/post/28063</link><guid isPermaLink="true">https://community.m5stack.com/post/28063</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Wed, 29 Jan 2025 08:14:45 GMT</pubDate></item><item><title><![CDATA[Reply to How to use DS18B20 or NTC10k in Uiflow? on Fri, 17 Jul 2020 10:17:06 GMT]]></title><description><![CDATA[<p dir="auto">The DS18B20 uses Maxim's exclusive 1-Wire bus protocol that implements bus communication using one control signal. The control line requires a weak pullup resistor since all devices are linked to the bus via a 3-state or open-drain port (the DQ pin in the case of the DS18B20).</p>
]]></description><link>https://community.m5stack.com/post/9355</link><guid isPermaLink="true">https://community.m5stack.com/post/9355</guid><dc:creator><![CDATA[Lewis-H]]></dc:creator><pubDate>Fri, 17 Jul 2020 10:17:06 GMT</pubDate></item><item><title><![CDATA[Reply to How to use DS18B20 or NTC10k in Uiflow? on Wed, 18 Mar 2020 00:34:12 GMT]]></title><description><![CDATA[<p dir="auto">Since there are no M5Stack products using these sensors, it is unlikely you will see blocks support for them in UiFlow unless you create it yourself. Therefore your best option is to switch to the micropython tab and follow a tutorial such as this <a href="https://randomnerdtutorials.com/micropython-ds18b20-esp32-esp8266/" target="_blank" rel="noopener noreferrer nofollow ugc">https://randomnerdtutorials.com/micropython-ds18b20-esp32-esp8266/</a> on how to read from the sensor in micropython.</p>
]]></description><link>https://community.m5stack.com/post/7792</link><guid isPermaLink="true">https://community.m5stack.com/post/7792</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 18 Mar 2020 00:34:12 GMT</pubDate></item></channel></rss>
