<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DAC module]]></title><description><![CDATA[<p dir="auto">I made a simple temperature regulator. I have attached a DAC module. Everything is fine when I send zero value - the module gives zero. If the value is greater than zero (1-100%) the DAC module gives 3.3 V or 100%. Do you have any description of how the DAC module works?</p>
]]></description><link>https://community.m5stack.com/topic/1484/dac-module</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 15:15:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1484.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Nov 2019 11:47:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DAC module on Thu, 12 Dec 2019 15:35:32 GMT]]></title><description><![CDATA[<p dir="auto">I tested the DAC module. You need to use dac0.writeData (Volt, save = True) in the range from 0 to 2700 to get from 0 to 3.3V. For variable indications to be similar to voltage, they should be divided by 0.00125.<img src="/assets/uploads/files/1576164901150-dac-resized.png" alt="0_1576164830010_DAC.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/6672</link><guid isPermaLink="true">https://community.m5stack.com/post/6672</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Thu, 12 Dec 2019 15:35:32 GMT</pubDate></item><item><title><![CDATA[Reply to DAC module on Fri, 22 Nov 2019 12:35:52 GMT]]></title><description><![CDATA[<p dir="auto">![alt text](image url) <a href="https://photos.google.com/photo/AF1QipMS4Ws6-kcJZl0RY_76b5v7PmTZ7ptHddbI-hJR" target="_blank" rel="noopener noreferrer nofollow ugc">https://photos.google.com/photo/AF1QipMS4Ws6-kcJZl0RY_76b5v7PmTZ7ptHddbI-hJR</a></p>
]]></description><link>https://community.m5stack.com/post/6475</link><guid isPermaLink="true">https://community.m5stack.com/post/6475</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Fri, 22 Nov 2019 12:35:52 GMT</pubDate></item><item><title><![CDATA[Reply to DAC module on Fri, 22 Nov 2019 03:41:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/2029">@kris</a> I don't have this module but I thought you would send a number, N,  up to 4095 and the output voltage would be 3.3 V * N/4096.  So I don't understand why you are sending a value in units of percent.  Maybe I'm taking your comment too literally.</p>
<p dir="auto">Also, another thing that confuses me is that the voltage being fed into the DAC from the Grove port is supposedly 5 V, so wouldn't the output of the DAC be 0 to 5V, not 0 to 3.3 V?</p>
<p dir="auto">I'm a chemical engineer, not an electrical engineer, but in the schematic it looks like there is nothing that is regulating the voltage from 5 V to 3.3 V.  The LM321MFX looks like a unity gain buffer.  Hopefully, someone with more knowledge will enlighten me.</p>
]]></description><link>https://community.m5stack.com/post/6472</link><guid isPermaLink="true">https://community.m5stack.com/post/6472</guid><dc:creator><![CDATA[Happy Hippo]]></dc:creator><pubDate>Fri, 22 Nov 2019 03:41:31 GMT</pubDate></item></channel></rss>
