<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[About Hat 8servos]]></title><description><![CDATA[<p dir="auto">I trying m5stickC+Hat 8servos, when I use UiFlow blocky code, it not work!<br />
But I use arduino code, it work.<br />
UiFlow version is 1.4.2</p>
]]></description><link>https://community.m5stack.com/topic/1474/about-hat-8servos</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 12:49:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1474.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Nov 2019 03:28:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to About Hat 8servos on Sun, 17 Nov 2019 11:45:55 GMT]]></title><description><![CDATA[<p dir="auto">Ah, that is worth Knowing thanks.<br />
I haven't got one yet so didn't know that they needed a "Initial Position" set up.<br />
Thank you for working this out.</p>
]]></description><link>https://community.m5stack.com/post/6419</link><guid isPermaLink="true">https://community.m5stack.com/post/6419</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 17 Nov 2019 11:45:55 GMT</pubDate></item><item><title><![CDATA[Reply to About Hat 8servos on Sun, 17 Nov 2019 05:23:58 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1573968211595-servo_setting-resized.jpg" alt="0_1573968183272_servo_setting.jpg" class=" img-fluid img-markdown" /><br />
I found a solution, I have to set it up first, then the servo can work.<br />
Thank you for your response.</p>
]]></description><link>https://community.m5stack.com/post/6411</link><guid isPermaLink="true">https://community.m5stack.com/post/6411</guid><dc:creator><![CDATA[coffeeworm]]></dc:creator><pubDate>Sun, 17 Nov 2019 05:23:58 GMT</pubDate></item><item><title><![CDATA[Reply to About Hat 8servos on Sun, 17 Nov 2019 05:08:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> said in <a href="/post/6407">About Hat 8servos</a>:</p>
<p dir="auto">you dont have power to the servos. is the power switch in the correct position?</p>
<p dir="auto">Yes,the power is switch in the correct position.<br />
I am sure that it is not a power problem.</p>
]]></description><link>https://community.m5stack.com/post/6410</link><guid isPermaLink="true">https://community.m5stack.com/post/6410</guid><dc:creator><![CDATA[coffeeworm]]></dc:creator><pubDate>Sun, 17 Nov 2019 05:08:01 GMT</pubDate></item><item><title><![CDATA[Reply to About Hat 8servos on Sat, 16 Nov 2019 19:18:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/2397">@coffeeworm</a> said in <a href="/post/6404">About Hat 8servos</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> said in <a href="/post/6403">About Hat 8servos</a>:</p>
<p dir="auto">pressure</p>
<p dir="auto">When the program is executed, the pressure on the servo horn is rotatable.</p>
<p dir="auto">as <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/2191">@Xeon</a> replied, you dont have power to the servos. is the power switch in the correct position?</p>
]]></description><link>https://community.m5stack.com/post/6407</link><guid isPermaLink="true">https://community.m5stack.com/post/6407</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 16 Nov 2019 19:18:13 GMT</pubDate></item><item><title><![CDATA[Reply to About Hat 8servos on Sat, 16 Nov 2019 18:23:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/2397">@coffeeworm</a><br />
Sounds like your not getting power.</p>
]]></description><link>https://community.m5stack.com/post/6405</link><guid isPermaLink="true">https://community.m5stack.com/post/6405</guid><dc:creator><![CDATA[Xeon]]></dc:creator><pubDate>Sat, 16 Nov 2019 18:23:46 GMT</pubDate></item><item><title><![CDATA[Reply to About Hat 8servos on Sat, 16 Nov 2019 12:57:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> said in <a href="/post/6403">About Hat 8servos</a>:</p>
]]></description><link>https://community.m5stack.com/post/6404</link><guid isPermaLink="true">https://community.m5stack.com/post/6404</guid><dc:creator><![CDATA[coffeeworm]]></dc:creator><pubDate>Sat, 16 Nov 2019 12:57:56 GMT</pubDate></item><item><title><![CDATA[Reply to About Hat 8servos on Sat, 16 Nov 2019 11:53:05 GMT]]></title><description><![CDATA[<p dir="auto">if you put pressure on the servo horn, does the horn move?</p>
]]></description><link>https://community.m5stack.com/post/6403</link><guid isPermaLink="true">https://community.m5stack.com/post/6403</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 16 Nov 2019 11:53:05 GMT</pubDate></item><item><title><![CDATA[Reply to About Hat 8servos on Sat, 16 Nov 2019 11:27:39 GMT]]></title><description><![CDATA[<p dir="auto">I record a mp4 video. The RGB worked but Servo not.<br />
<a href="https://youtu.be/iymi3ziUE7M" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/iymi3ziUE7M</a></p>
]]></description><link>https://community.m5stack.com/post/6401</link><guid isPermaLink="true">https://community.m5stack.com/post/6401</guid><dc:creator><![CDATA[coffeeworm]]></dc:creator><pubDate>Sat, 16 Nov 2019 11:27:39 GMT</pubDate></item><item><title><![CDATA[Reply to About Hat 8servos on Sat, 16 Nov 2019 11:20:06 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1573903198276-snap6-resized.jpg" alt="0_1573903131755_Snap6.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/6400</link><guid isPermaLink="true">https://community.m5stack.com/post/6400</guid><dc:creator><![CDATA[coffeeworm]]></dc:creator><pubDate>Sat, 16 Nov 2019 11:20:06 GMT</pubDate></item><item><title><![CDATA[Reply to About Hat 8servos on Sat, 16 Nov 2019 09:45:39 GMT]]></title><description><![CDATA[<p dir="auto">Can you share a screen shot of you UIFlow code please?</p>
]]></description><link>https://community.m5stack.com/post/6396</link><guid isPermaLink="true">https://community.m5stack.com/post/6396</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 16 Nov 2019 09:45:39 GMT</pubDate></item></channel></rss>
