<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update m5Stack to 1.3.2]]></title><description><![CDATA[<p dir="auto">I can see the m5stack on my windows 10 machine at COM11 with the correct driver. When I try to burn the new software I see the following which seems to suggest that m5burner (or some other component) cannot .. any ideas? Thanks!</p>
<li>Command:<br />
--chip esp32 --port COM11 --baud 921600 --before default_reset --after no_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x10000 application_0x10000.bin 0x1000 bootloader_0x1000.bin 0x1f0000 fatfsImg_0x1f0000.img 0x8000 partitions_0x8000.bin<br />
===================================================<br />
[25524] Failed to execute script esptool<br />
File "<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a>", line 2849, in &lt;module&gt;<br />
File "<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a>", line 2842, in <em>main<br />
File "<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a>", line 2549, in main<br />
File "<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a>", line 213, in <strong>init</strong><br />
File "site-packages\serial_<em>init</em></em>.py", line 88, in serial_for_url<br />
File "site-packages\serial\<a href="http://serialwin32.py" target="_blank" rel="noopener noreferrer nofollow ugc">serialwin32.py</a>", line 62, in open<br />
serial.serialutil.SerialException: could not open port 'COM11': PermissionError(13, 'A device attached to the system is not functioning.', None, 31)<br />
<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v2.5.0<br />
Serial port COM11</li>
]]></description><link>https://community.m5stack.com/topic/1080/update-m5stack-to-1-3-2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 07:39:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1080.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Jun 2019 17:10:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update m5Stack to 1.3.2 on Thu, 13 Jun 2019 17:46:12 GMT]]></title><description><![CDATA[<p dir="auto">Check your usb cable, sometimes the cables dont work.</p>
]]></description><link>https://community.m5stack.com/post/4623</link><guid isPermaLink="true">https://community.m5stack.com/post/4623</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 13 Jun 2019 17:46:12 GMT</pubDate></item></channel></rss>
